Uploading to VPN-CNs?
gravityhammer
I'm on an "easy upgrade" (as if there ever were such a thing) to a job that has three VPN-CPs. I've tried uploading through the master, as well as loading through the 2.5mm jack, with no luck. I've confirmed that my baud rate is correct (38400) for the direct-serial approach, but I keep getting the response:
"Cannot perform download:
The panel screen size differs from the TPD file"
I'm updating the files that were given to me, which are VPN-CP files. What gives with the error message?
The message means that the TPD file you have is not made for the panel you are sending it to, that the screen resolution does not match. A VPN-CP is 320 wide by 240 pixels high.
Load your panel project into TPDesign and see what IT thinks it is. Let us know.
I am trying to load it through TPDesign, which confirms that it is the right panel type.
Sent from my LG-P999 using Tapatalk
Vincèn
I'd say the file is corrupted, or the firmware in the VPN is ancient... or the VPN has failed. This works when things are right.
Maybe resave the file from TPD and exit, restart, load again...
Did you try to send first just pages ? or reset the panel itself ? sometimes memory in panel can be corrupted ! try also slower speed ? did u check also com port is not busy by NetLinx Studio ? just some ideas.
Vincèn
Vincèn
