Having trouble with Extron crosspoint 300 swicther duet module
Hi Friends,
I m having trouble programming the Extron crosspoint 300.At first i tried my own code doing the normal send string commands 1*1! ,2*1! etc .But there is no effect on the crosspoint.After many tries,i gave up and decided to download the extron crosspoint 300 Duet module from AMX website.When i press the button on the touch panel only the input and output buttons blink ,no led activity on Rx and Tx.Maybe i m not loading the duet module correctly or there is something else im doing wrong.
Thanks and Regards
Ajay
Thanks and Regards
Ajay
What are the firmware updates i have to do ?
1.Ni Series Duet master firmware
2.Ni Series device firmware
Find out if you can make the Extron switch using your cable attached to your PC and sending from hyperterminal or from something better like HEXCOMTOOL. If you can't make it switch from a keyboard, DUET modules can't fix it.
i have checked the cable and baudrate,no problem there.I also connected the same cable to the pc to connect to an extron switcher software it works fine.
When i made my own code .the Rx and Tx LED's used to blink but the switcher does not respond the way i want.
I have attached the Extron duet code.The only thing i changed in the code was remove the IP device definition and activate the rs232 device 5001:1:0
