Proper device boot sequence?
rrdbstudios
All,
I recently had made changes to a master, which is a master master to a larger system; it ended up working however causing issues with other things, so until we can fix these problems, I reverted to the prior code.
I have been made aware that 2 codecs connected to this master master are not communicating with the local TP for the master master or the adjacent control room, which remotely controls this master master.
They are tandberg mxp6k codecs, and are powered on, however key presses blink the input light on the master, however the TX/RX lights do nothing.
I am not onsight, and can only direct people on site.
I am assuming that the connection between the master and the codec is the problem, ie. no handshake essentially between the comm ports on the master and the codecs. ?
What would be the proper order to ensure everything comes online.
I have always made sure the devices were fully on before rebooting the master, but would it be better to completely boot the master then boot each device individually?
Again, being that I'm not onsite, I cannot watch diagnostics as devices come online, etc...
Any insight would be great!
Thanks all.
Thanks all.
If your code is blocking strings to "offline" devices then you need to figure out why the devs are offline and in most cases power on devices before booting the master is preferred.
If your code isn't blocking strings based on "online" status then your TX should at least be flashing regardless of the device's state, powered on or off. So why isn't TX flashing?
Since TX leds aren't flashing I would say your code is either blocking based on "online" status, the master has the dreaded cap issue or your M2M url list has changed (if this issue spans masters). This assumes your running the code that previously worked.
Ill reply back once I hear back, if there is anything new to add.
thanks vining!
Edit: (Here's the code to see if anything does stand out: this is the local code that directly connects to the codecs. )
DEFINE_DEVICE{
// NI 4100 *************************************************
dvCodec1 = 5001:1:0 // Tandberg MXP Codec
dvCodec2 = 5001:2:0 // Tandberg MXP Codec
vdvCodec1_1 = 41001:1:0
vdvCodec1_2 = 41001:2:0
vdvCodec1_3 = 41001:3:0
vdvCodec2_1 = 41002:1:0
vdvCodec2_2 = 41002:2:0
vdvCodec2_3 = 41002:3:0
dvTP1_C = 10001:3:0 // Reserved for Codecs
//...... other TP stuff..
DEFINE_VARIABLE{
INTEGER nSelectedCodec[MAX_PANELS]
VOLATILE DEV dvCodecs[]=
dvCodec1,
dvCodec2
// dvCodec3
VOLATILE DEV vdvCodecsPort1[]=
vdvCodec1_1,
vdvCodec2_1
// vdvCodec3_1
VOLATILE DEV vdvCodecsPort2[]=
vdvCodec1_2,
vdvCodec2_2
// vdvCodec3_2
VOLATILE DEV vdvCodecsPort3[]=
vdvCodec1_3,
vdvCodec2_3
// vdvCodec3_3
VOLATILE INTEGER nCodecBtns[]=
151, // Transmitting (feedback only)
152, // Disconnect (Hang Up)
153, // Duo Video toggle
154 // Mic On/Off
VOLATILE INTEGER nCodec2Btns[]=
251, // Transmitting (feedback only)
252, // Disconnect (Hang Up)
253, // Duo Video toggle
254 // Mic On/Off
DEFINE_START{
DEFINE_MODULE 'Tandberg_MXP_Comm_dr1_0_0' modCodec1(vdvCodec1_1,dvCodec1)
DEFINE_MODULE 'Tandberg_MXP_Comm_dr1_0_0' modCodec2(vdvCodec2_1,dvCodec2)
DEFINE_EVENT{
BUTTON_EVENT[dvTPC,150] // "YES" BUTTON ON THE "VTC WARNING" PAGE. SERVES AS CONFIRMATION.
{ // PAGE SHOWN ID USER TRIES TO DISCONNECT WHILE A VTC CALL IS ACTIVE
PUSH :
OFF[vdvCodec1_1,238] // HANG UP / DISCONNECT CODEC
OFF[vdvCodec1_2,238] // HANG UP / DISCONNECT CODEC
// SEND_COMMAND dvTPA,'@PPX'
// SEND_COMMAND dvTPA,'PAGE-Security Level'
// SEND_COMMAND dvTPA,'PPN-Security Level Title'
BUTTON_EVENT[dvTPC,164] // Selfview
PUSH :
TO [vdvCodec1_1,191]
BUTTON_EVENT[dvTPC,165] // Pip
PUSH :
TO [vdvCodec1_1,193]
BUTTON_EVENT[dvTPC,141] // Camera Input
PUSH :
TO [dvTPC,BUTTON.INPUT.CHANNEL]
SEND_COMMAND vdvCodec1_3,'INPUTSELECT-1'
IF (![vdvCodec1_1,309])
SEND_COMMAND vdvCodec1_1,'INPUT-CAMERA,1'
BUTTON_EVENT[dvTPC,142] // PC Input
PUSH :
SEND_COMMAND vdvCodec1_1,'INPUT-DVI,1'
ELSE
SEND_COMMAND vdvCodec1_2,'INPUT-DVI,1'
BUTTON_EVENT[dvTPC,250] // "YES" BUTTON ON THE "VTC WARNING" PAGE. SERVES AS CONFIRMATION.
PUSH :
OFF[vdvCodec2_1,238] // HANG UP / DISCONNECT CODEC
OFF[vdvCodec2_2,238] // HANG UP / DISCONNECT CODEC
BUTTON_EVENT[dvTPC,264] // Selfview
PUSH :
TO [vdvCodec2_1,291]
BUTTON_EVENT[dvTPC,265] // Pip
PUSH :
TO [vdvCodec2_1,293]
BUTTON_EVENT[dvTPC,241] // Camera Input
PUSH :
SEND_COMMAND vdvCodec2_3,'INPUTSELECT-1'
IF (![vdvCodec2_1,309])
SEND_COMMAND vdvCodec2_1,'INPUT-CAMERA,1'
BUTTON_EVENT[dvTPC,242] // PC Input
PUSH :
SEND_COMMAND vdvCodec2_1,'INPUT-DVI,1'
ELSE
SEND_COMMAND vdvCodec2_2,'INPUT-DVI,1'
BUTTON_EVENT[dvTPC,nCodecBtns]
PUSH :
LOCAL_VAR INTEGER nIndex
nIndex = GET_LAST(nCodecBtns)
SWITCH (nIndex)
CASE 2: // Hang Up/Disconnect
CASE 3: // DuoVideo toggle
IF ([vdvCodec1_1,238])
PULSE[vdvCodec1_1,308]
ELSE
SEND_COMMAND dvTPA[GET_LAST(dvTPA)],'ADBEEP' // only when in a call
CASE 4: // Mic Toggle
PULSE [vdvCodec1_1,145]
BUTTON_EVENT[dvTPC,nCodec2Btns]
PUSH :
nIndex = GET_LAST(nCodec2Btns)
SWITCH (nIndex)
IF ([vdvCodec2_1,238])
PULSE[vdvCodec2_1,308]
ELSE
PULSE [vdvCodec2_1,145]
DEFINE_PROGRAM{
[dvTPC,nCodecBtns[1]] = ([vdvCodec1_1,238] || [vdvCodec1_2,238] || [vdvCodec1_3,238])
[dvTPC,nCodecBtns[3]] = [vdvCodec1_1,309]
[dvTPC,nCodecBtns[4]] = [vdvCodec1_1,146]
[dvTPC,nCodec2Btns[1]] = ([vdvCodec2_1,238] || [vdvCodec2_2,238] || [vdvCodec2_3,238])
[dvTPC,nCodec2Btns[3]] = [vdvCodec2_1,309]
[dvTPC,nCodec2Btns[4]] = [vdvCodec2_1,146]
If the tandberg is fully online when the amx system boots, and they aren't handshaking properly, i would double check everything about the connection between them. Make sure the baud rate on all devices is set correctly, make sure the cables are plugged in all the way, try replacing the cable, ect.
-Ryan
I would personally investigate the following:
1 - There are known issues between certain firmware/development environment Duet versions. Update your AMX tools including the Duet runtimes and update the firmware on the control system.
2 - You don't seem to be explicitly setting the baud rate for the device. From the Duet module document:
As for firmware/software versions. This is the original netlinx software vers and firmware verions loaded when this system was initially built; it is completely disconnected from the internet and will never be connected.
So there should not be any change in software versions; I assume this was related to duet dependencies?
...if so, I did oringinally think about this, however because of the environment and 24/7 opperation of this system. nothing is tounched and all is houses in secure environments where nobody can access the physical units except people like me... who are unforntunetly thoasands of miles from them..
This is my thought.
Hopefully once we get this fixed, I can post a reason, but for others in the future if they come across this problem, maybe this will help them visualize my possible problem....
Just from playing aroudn here, I have tried to see how I could mess up a connection between the codec (which i dont have one local to truly test), but here is what I got from changing netlinx versions vs firmware verisons on my test 3100
This is the failed to load drivers.
Line 47 (14:54:40):: DA.processNewDevice: {Device-Revision=1.0.0, Device-Category=ip,serial,rs-232, Device-Make=TANDBERG, Physical-Device=5001:1:0, obje
Line 48 (14:54:40):: ctClass=[Ljava.lang.String;@aab411, Device-SDKClass=com.amx.duet.devicesdk.VideoConferencer, Bundle-Version=2.0.0, Device-Model=MXP
Line 49 (14:54:40):: ,3000MXP,6000MXP, Duet-Device=41001:1:0, service.id=4, Duet-Module=TANDBERG_MXP_COMM_dr1_0_0}
Line 50 (14:54:46):: Device Access: DeviceAccess.loadDrivers - failed to resolve dependencies for /bundle/TANDBERG_MXP_COMM_dr1_0_0
Heres successfully loading drivers:
Line 127 (15:36:50):: DA.processNewDevice: {Device-Make=TANDBERG, Duet-Device=41002:1:0, Duet-Revision=1.0.0, Device-Revision=1.0.0, Device-SDKClass=com.
Line 128 (15:36:50):: mx.duet.devicesdk.VideoConferencer, Physical-Device=5001:2:0, Device-Channels=350, Poll_Time=10000, Device-Levels=30, objectClass=[
Line 129 (15:36:50):: java.lang.String;@4b7996, service.id=8, Duet-Make=TANDBERG, Device-Service=com.amx.duet.routers.snapi.ISNAPIRouter, IP_Address=10.0
Line 130 (15:36:50):: 0.1, Bundle-Version=2.0.0, Timeout_Count=3, Port=23, Device-Model=MXP,3000MXP,6000MXP, Baud_Rate=9600, Duet-Model=MXP,3000MXP,6000M
Line 131 (15:36:50):: P, Device-Category=ip,serial,rs-232}
Line 132 (15:36:50):: Memory Available = 36631160 <12144>
Line 133 (15:36:50):: DriverLocatorSnapiImpl.loadDriver : hits found = 1
Line 134 (15:36:50):: DriverLocatorSnapiImpl.loadDriver : drivers found = 1
Line 135 (15:36:50):: SNAPIRouter: VideoConferencerComponent loaded
Line 136 (15:36:50):: SNAPIRouter: DialerComponent loaded
Line 137 (15:36:50):: SNAPIRouter: VolumeComponent2 loaded
Line 138 (15:36:51):: SNAPIRouter: PhonebookComponent loaded
Line 139 (15:36:51):: SNAPIRouter: SourceSelectComponent3 loaded
Line 140 (15:36:51):: SNAPIRouter: PowerComponent loaded
Line 141 (15:36:51):: SNAPIRouter: CameraComponent2 loaded
Line 142 (15:36:51):: SNAPIRouter: MenuComponent loaded
Line 143 (15:36:51):: SNAPIRouter: ModuleComponent loaded
Line 144 (15:36:51):: CIpEvent::OnLine 41002:1:2056
