EXB COM over the internet
I haven't seen one of the new ICSLan devices, but could you locate one at a remote site, and using port forwarding over 1319, use it to control a device at a remote location without having a local master at the remote location? I know they get a virtual device number from the master, but I'm not sure how it gets an IP address so that it can be identified across subnets .
  • John NagyJohn Nagy Posts: 1,746
    No need to not be sure about this, it is quite completely documented in the manual, available free on the AMX product page. Several pages are dedicated to IP options (there are many) in detail.
    The answer is YES.
    I just VPN'ed into one of my systems and it has an EXB-I/O8. I recall having to set the IP address via telnet. Here's the output of the telnet:
    Welcome to EXB-I/O8 v1.0.49 Copyright AMX LLC 2011
    >superuser
    >help
    ----- Help -----       (Extended diag messages are OFF)
    ? or Help              This list.
    reboot                 Reboots the device.
    factoryfwimage         Revert to the factory firmware image and parameters.
    reset factory          Revert to the factory parameters.
    device status [D:P:S]  Display info about this device.
    get dns                Show the DNS configuration of a device.
    get sn                 Show the serial number of a device.
    get ip                 Show the IP configuration.
    get config             Show the current configuration.
    get connection         Show consolidated list of master connection settings.
    get device             Show device number.
    get friendly           Get friendly name.
    get location           Get location name.
    get ethernet mode      Get ethernet mode.
    ndp unbind             Clears NDP binding (requires reboot to take effect)
    ping [address]         Pings an address. Address may be an IP or URL.
    renew dhcp             Renews the DHCP lease (may cause telnet disconnection.
    set ip                 Setup the IP configuration of a device.
    set dns                Setup the DNS configuration of a device.
    set device [num]       Set device number to [num].
    set connection         Set the master connection settings.
    set friendly [name]    Set friendly name to [name].
    set location [loc]     Set location to [loc].
    set telnet port        Sets the IP port listened to for telnet connections.
    set ethernet mode [m]  Set ethernet mode to [m], where [m] is
                           'auto' or '100 full' or '10 half'
    show connection log    Show the connection logs for the device.
    show connection stats  Show ICSP connection statistics.
    show log <start>       Display the message log. <start> specifies message
    msg on|off             Enable/disble diagnostic msgs .
    exit                   Close this telnet session.
    Per the manual for ICSLan boxes: "By default, the EXB Modules are set to DHCP Mode."
  • John Nagy wrote: »
    The answer is YES.
    Lol, did you just tell Paul to RTFM? "Yes" would have sounded a lot less snottier :)
    jjames wrote: »
    Ah yes the manual. AMX TS told me they don't recommend using them in the way I described, so I didn't think the manual would clear that up. But if its just another IP device on the network that uses ICSP, there should be no theoretical reason why it can't be placed in a remote location and as long as the networking, DNS, etc is setup correctly it would work reliably. But often reality isn't so simple so I am curious if someone has set this up that way in the real world using the real internet with a chatty two way device.
    I think you might consider a touch panel to be a chatty device, using ICSP at 1319 with a local IP address and an AXLINK address, so it is the same scenario. We regularly use them remotely as you describe, even between continents. We use it often for demos so dealers and customers can hold a real panel in their hands wherever they are and operate a live system. TPControl technicians test releases from London and Australia against our California Netlinx, using the exact method you suggest.
    I'm not sure why tech support would recommend against it, other than unfamiliarity with the scenario. Perhaps there are security concerns. ICSP security should help that. It should be as stable as the Internet connection itself. Note that an old product, the AXB-NET, was exactly for this remote linkage purpose, to provide "local" AXLINK at a location only reachable by network or Internet.
    The manual does go on for pages about setup options and modes of communication, beyond those suggested by the telnet menu. It has a dropback mode for when there is no DHCP available, it sniffs the network map and tries to find a place that isn't in use, pretty cool. It defaults to DHCP as all AMX, indeed nearly all network devices, do... gotta start somewhere.
    We all have been disappointed in documentation on occasions, but c'mon, if you want an answer, why not start with the answer document? I think it's just good advice to suggest that experienced AMX professionals consult the free and available documentation that is prepared in detail specifically to help use the product before calling tech support or waving a white flag in the forums. Even when that works as a shortcut, you often don't have the whole answer and breadth of options explained as the documentation MIGHT, giving you new and different ideas of how you might better accomplish your desired ends.
    I know I always learn something new when I RTFM.
    John Nagy wrote: »
    I wouldn't call a touch panel a chatty device, but then I don't send them 20,000 commands when they come online.
    John Nagy wrote: »
    I have nothing against manuals I read them all day long. They don't give you the real world situation in all cases though. Whether this device can maintain a reliable connection across the internet over VPN with 2 way communication with a chatty device like a lighting system is something you tend to only find out by doing it. Even a little latency in a real time system can make it unusable.
    I expect it will work as well as your network does. Let us know....
    After more experience with the ICSLAN boxes, specifically the EXB-COM2, I'm kind of appalled.
    After much hassle and customer/dealer angst due to a projector and an AVR working one day and not the next, using one of these for SERIAL... we find it reverts to 9600 baud on its own.
    Combing the documentation, in a single notation in the BAUD section for all the ICSLAN products, it warns that the baud rate is NOT stored in any nonvolatile memory and will be lost on power failure (or in our case, moderate power bumps). So it's not safe to set and forget, you must actively renew the baud rate to keep it going.
    Your choices:
    * Set the device controlled to 9600 baud so you don't need to tend to it at all
    * Frequently refresh the baud set initialization, perhaps every time you talk to the device (ugh)
    * Actively watch for the device online event and renew the initialization each time
    * Buy a different solution at 1/4 the price that just works like you expect. Nearly any other brand costs less and works without holding its hand.
    The convenience of the devices showing up as native AMX devices is nice and eases coding, but is far offset by the burden of coding a reinitialization scheme.
    I'm disappointed and kind of shocked that AMX would add such a needy product line (as such posh prices) to their commercial - focused lineup. This EXB-COM2 LAN unit replaces the AXB-232++ in a sense... that was designed 15 years ago or more, and a unit set up 15 years ago will still be running at the set baud today, come hell or high voltage.
    First - thanks for the information! I believe we'll be installing one of these shortly, so this is good to know. However...
    John Nagy wrote: »
    *Actively watch for the device online event and renew the initialization each time
    Isn't that where one would put the baud rate information to begin with? I've never done a "set and forget" and always put a SET BAUD command in the ONLINE event.
    Do you mean something else or do you just do it differently than I?
    jjames wrote: »
    The "native" serial ports (5001) on the NetLinx, we've always initialized at power up and data reset. In 20 years with AMX and for 50 dealers using our stuff, that's been often enough until now. External serial ports on slaves, same. IP-to-Serial devices like DIGI-ONE and Global Cache, set them once in their internal settings. AXB-boxes or cards, set the dip switches and forget about it.
    In the case at hand, it's not clear from logs that it even ever went offline, but still forgot its baud. We've never before encountered transitory serial ports that you must presume don't know what to do even if you told it a minute ago. I suppose there may be others, but this was new in our experience. Certainly unlike anything we've worked with from AMX to date. Maybe we've led a sheltered life.
    As we don't believe we can trust watching for online events, we've added automatic reinitialization of all serial ports upon any room-on event for our solution. And recommending against use on unattended devices such as alarms or lighting control unless you can set them to 9600 baud.
    Regardless, I conclude that there are better choices one might make than to buy these.
    Gotcha! Thanks again for the info.
