Panasonic DW6300 IP control
Has anyone controlled the DW6300 through IP control. I have the port as 1024. I tried to control using the RS2322 code and does not work. I think I am missing something. It looks like I have to use MD5 algorithim. Is there anyway I do not have to use that. Thank you. Kenny A
    From memory - I think if you use the projector menu config to remove password protection it will disable the MD5 requirement.
    viningvining Posts: 4,368
    kennyann wrote: »
    AMXJeff posted a Cypher Module back in 2008 (?) when I needed MD5 encoding for a module I was working on. If you do a search you should be able to find it. Even if you find you can defeat the login requirements you might want to add it to your arsenal for future needs.
    kennyannkennyann Posts: 113
    Thanks for the answer guys - how do I remove the password - do just leave teh password blank. There are not enable or disable features for the password - there are enable and disable control features for Web Control, RS232 Control, PJLink, and Control port. Thank you.
