GET method control HTTP VLC
I want to share an example with VLC via HTTP
I propose here to share management capabilities VLC.
Here is an example of the GET method with VLC.
VLC player, perform management through the management interface to the HTTP server example
Host server: 10.0.7.18 port 8081
PROGRAM_NAME='Main Program'
(*  FILE_LAST_MODIFIED_ON: 04/05/2006  AT: 09:00:25        *)
(* System Type : NetLinx                                   *)
(* REV HISTORY:                                            *)
    $History: $
dvIPDeviceVLC 		= 0:5:0
dvTP			= 32000:1:0
(*               CONSTANT DEFINITIONS GO BELOW             *)
DEFINE_CONSTANT
CHAR cDevTelnetVLC[15] = '10.0.7.18'  		//IP Address VLC server
INTEGER nIPPORT		=	8081		/// IP PORT VLC server
INTEGER nProtocol	=	1
LONG tlOnline	=	1
(*              DATA TYPE DEFINITIONS GO BELOW             *)
DEFINE_TYPE
integer nOnline
integer nOffline
integer nError
integer nData
integer btnCtr[]	=
			    1,
			    2,
			    3,
			    4,
			    5,
			    6,
			    7,
			    8,
			    9
DEFINE_FUNCTION CHAR[100] SMTPGetIpError (LONG nNUM)
     SWITCH (nNUM)
	  //// ERROR REPORTING
	  CASE 2:
	       RETURN "'IP ERROR (',ITOA(nNUM),'): General Failure (IP_CLIENT_OPEN/IP_SERVER_OPEN)'"
	  CASE 4:
	       RETURN "'IP ERROR (',ITOA(nNUM),'): Unknown host (IP_CLIENT_OPEN)'"
	  CASE 6:
	       RETURN "'IP ERROR (',ITOA(nNUM),'): Connection refused (IP_CLIENT_OPEN)'"
	  CASE 7:
	       RETURN "'IP ERROR (',ITOA(nNUM),'): Connection timed out (IP_CLIENT_OPEN)'"
	  CASE 8:
	       RETURN "'IP ERROR (',ITOA(nNUM),'): Unknown connection error (IP_CLIENT_OPEN)'"
	  CASE 9:
	       RETURN "'IP ERROR (',ITOA(nNUM),'): Already closed (IP_CLIENT_CLOSE/IP_SERVER_CLOSE)'"
	  CASE 14:
	       RETURN "'IP ERROR (',ITOA(nNUM),'): Local port already used (IP_CLIENT_OPEN/IP_SERVER_OPEN)'"
	  CASE 16:
	       RETURN "'IP ERROR (',ITOA(nNUM),'): Too many open sockets (IP_CLIENT_OPEN/IP_SERVER_OPEN)'"
	  CASE 17:
	       RETURN "'IP ERROR (',ITOA(nNUM),'): Local Port Not Open (IP_SERVER_OPEN)'"
	  DEFAULT:
	       RETURN "'IP ERROR (',ITOA(nNUM),'): Unknown'"
(*               LATCHING DEFINITIONS GO BELOW             *)
DEFINE_LATCHING
(*       MUTUALLY EXCLUSIVE DEFINITIONS GO BELOW           *)
DEFINE_MUTUALLY_EXCLUSIVE
(*        SUBROUTINE/FUNCTION DEFINITIONS GO BELOW         *)
(*                STARTUP CODE GOES BELOW                  *)
IP_CLIENT_OPEN(dvIPDeviceVLC.PORT,cDevTelnetVLC,nIPPort,IP_TCP) /// OPEN IP CONNECTION
(*                THE EVENTS GO BELOW                      *)
DATA_EVENT[dvIPDeviceVLC]
     ONLINE:
	  nOnline = 100
	  SEND_STRING 5001:0:0,"'dv1-DEVICE ONLINE- PORT ',ITOA(data.device.port)"/// TELL ME ABOUT IT
     OFFLINE:
	  nOffline = 100
	  SEND_STRING 5001:0:0,"'dv1-DEVICE OFFLINE- PORT ',ITOA(data.device.port)" /// TELL ME ABOUT IT
     ONERROR:
	  nError = 100
	  // Print error
	  SEND_STRING 5001:0:0,"'dv1-REPORT- PORT ',ITOA(data.device.port),'-',SMTPGetIpError(Data.Number)" /// TELL ME ABOUT THE ERROR
	  /// Act Accordingly
	  SWITCH(data.number)
	       CASE 14:
	       CASE 17:
     STRING:
	  nData = 100
	  SEND_STRING 5001:0:0, data.text
BUTTON_EVENT [dvTP, btnCtr]
	SWITCH (button.input.channel)
	    case 1: //pause
		send_string dvIPDeviceVLC, "'GET /requests/status.xml?command=pl_pause HTTP/1.0',$0D,$0A,$0D,$0A"
	    case 2: //play
		send_string dvIPDeviceVLC, "'GET /requests/status.xml?command=pl_play HTTP/1.0',$0D,$0A,$0D,$0A"
	    case 3: //stop
		send_string dvIPDeviceVLC, "'GET /requests/status.xml?command=pl_stop HTTP/1.0',$0D,$0A,$0D,$0A"
	    case 4: //next
		send_string dvIPDeviceVLC, "'GET /requests/status.xml?command=pl_next HTTP/1.0',$0D,$0A,$0D,$0A"
	    case 5: //previous
		send_string dvIPDeviceVLC, "'GET /requests/status.xml?command=pl_previous HTTP/1.0',$0D,$0A,$0D,$0A"
	    case 6: //pl_delete
		send_string dvIPDeviceVLC, "'GET /requests/status.xml?command=pl_delete HTTP/1.0',$0D,$0A,$0D,$0A"
	    case 7: //pl_loop
		send_string dvIPDeviceVLC, "'GET /requests/status.xml?command=pl_loop HTTP/1.0',$0D,$0A,$0D,$0A"
	    case 8: //pl_repeat
		send_string dvIPDeviceVLC, "'GET /requests/status.xml?command=pl_repeat HTTP/1.0',$0D,$0A,$0D,$0A"
	    case 9: //fullscreen
		send_string dvIPDeviceVLC, "'GET /requests/status.xml?command=fullscreen HTTP/1.0',$0D,$0A,$0D,$0A"
(*            THE ACTUAL PROGRAM GOES BELOW                *)
DEFINE_PROGRAM
(*                     END OF PROGRAM                      *)
(*        DO NOT PUT ANY CODE BELOW THIS COMMENT           *)
  • vincenvincen Posts: 526
    Thanks for the share ;)
  • not for that,
    I would appreciate if anyone share the parser (feedback) to process the HTML code.
  • continue,
    feedback example:
    (* REV HISTORY:                                            *)
        $History: $
    dvTP			= 34001:1:0  //test virtual device
    DEFINE_CONSTANT
    LONG tlOnline	=	1
    DEFINE_TYPE
    STRUCTURE t_StatusVLCPayer
        char pVOLUME[100]
        char pLENGHT[100]
        char pTIME[100]
        char pSTATE[100]
        char pPOSITION[100]
        char pFULLSCREEN[100]
        char pRANDOM[100]
        char pLOOP[100]
        char pREPEAT[100]
        char pTITLE[100]
        char pARTIST[100]
        char pREADBYTES[100]
    t_StatusVLCPayer StatusVLCPayer
    char bufferVLC[5000]
    integer nOnline
    integer nOffline
    integer nError
    integer nData
    integer btnCtr[]	=
    			    1,
    			    2,
    			    3,
    			    4,
    			    5,
    			    6,
    			    7,
    			    8,
    			    9,
    			    10
    integer POS, POS2, inc
    integer posSt
    integer posEnd
    integer lengthPos
    char u[20],r[20]
         SWITCH (nNUM)
    	  CASE 2:
    	  CASE 4:
    	  CASE 6:
    	  CASE 7:
    	  CASE 8:
    	  CASE 9:
    	  CASE 14:
    	  CASE 16:
    	  CASE 17:
    	  DEFAULT:
    DEFINE_FUNCTION char[100] fnParserState (char txtHTML[5000], char txtState[20])
        IF ((FIND_STRING(txtHTML,"'</',txtState,'>'",1)) && (FIND_STRING(txtHTML,"'<',txtState,'>'",1)))
    	u = txtState
    	r = "'<',txtState,'>'" //l=8
    	lengthPos = length_string(r)//("'<',txtState,'>'")		// <volume> l=12
    	posSt = FIND_STRING(txtHTML,"'<',txtState,'>'",1) + lengthPos	// + length_string("'<',txtState,'>'")
    	posEnd = FIND_STRING(txtHTML,"'</',txtState,'>'",1)
    	RETURN mid_string(txtHTML, (posSt), (posEnd-posSt))
        ELSE
    	RETURN 'Error'
    DEFINE_LATCHING
    create_buffer dvIPDeviceVLC, bufferVLC
         ONLINE:
    	  nOnline = 100
    	  SEND_STRING 5001:0:0,"'DEVICE ONLINE- PORT ',ITOA(data.device.port)"/// TELL ME ABOUT IT
         OFFLINE:
    	  nOffline = 100
    	  SEND_STRING 5001:0:0,"'DEVICE OFFLINE- PORT ',ITOA(data.device.port)" /// TELL ME ABOUT IT
         ONERROR:
    	  nError = 100
    	  // Print error
    	  SEND_STRING 5001:0:0,"'REPORT- PORT ',ITOA(data.device.port),'-',SMTPGetIpError(Data.Number)" /// TELL ME ABOUT THE ERROR
    	  /// Act Accordingly
    	  SWITCH(data.number)
    	       CASE 14:
    	       CASE 17:
         STRING:
    	stack_var char param[20]
    	inc++
    	  nData = 100
    //	  param = 'volume'
    	 StatusVLCPayer.pVOLUME = fnParserState (bufferVLC, 'volume')
    	  StatusVLCPayer.pLENGHT = fnParserState (bufferVLC, 'length')
    	  StatusVLCPayer.pTIME = fnParserState (bufferVLC, 'time')
    	  StatusVLCPayer.pSTATE = fnParserState (bufferVLC, 'state') //playing or stopping negative
    	  StatusVLCPayer.pPOSITION = fnParserState (bufferVLC, 'position')
    	  StatusVLCPayer.pFULLSCREEN = fnParserState (bufferVLC, 'fullscreen')
    	  StatusVLCPayer.pRANDOM = fnParserState (bufferVLC, 'random')
    	  StatusVLCPayer.pLOOP = fnParserState (bufferVLC, 'loop')
    	  StatusVLCPayer.pREPEAT = fnParserState (bufferVLC, 'repeat')
    	  StatusVLCPayer.pTITLE = fnParserState (bufferVLC, 'title')
    	  StatusVLCPayer.pARTIST = fnParserState (bufferVLC, 'artist')
    	bufferVLC = ''
    	    case 1: //pause
    	    case 2: //play
    	    case 3: //stop
    	    case 4: //next
    	    case 5: //previous
    	    case 6: //pl_delete
    	    case 7: //pl_loop
    	    case 8: //pl_repeat
    	    case 10: //test
    		POS2 = 500
    DEFINE_PROGRAM
    I'm curious why you are sending strings to device 5001:0:0.
  • jimmywjimmyw Posts: 112
    its funny, I thought it was odd too, but, its seems like its actually the "netlinx" way to do it instead of the "axlink" way.
    but I would assume it would be 0:0:0 not 5001:0:0
    jimmyw wrote: »
    While what you say is true it hits wide of my question. I'm not the best communicator. :) The thrust of my question was to ask for what reason he was sending notifications to the NI device and not the master. My guess is that he was assuming he WAS sending notifications to the master and not the device portion of the box.
    I've seen a lot of programmers not quite get the concept of the integrated master. It's seems that some people have a hard time getting their head around the idea that the box actually contains several little boxes (conceptually) integrated on the same PC board.
    Also, I was curious if there was some new exciting thing I didn't know about that sending to port zero on the NI device facilitated or something.
    e
  • ericmedley wrote: »
    I have been an example to work with VLC player.
    Send to a device 5001:0:0, I was comfortable watching message in the notification window. You can also look in the Diagnostic window, sending send_string 0, "'xxx'", including Diagnostics -> Enabe Netlinx Internal Diagnostics Messages
  • tell me please,
    How to send a message Invite device - 0:5:0 (local port) through the window "Control a Device .."
    I try to send a Control a Device .. (Device - 0, Port - 5, System - an, Message (s) to Send check String Expressions - "'GET / requests / status.xml? Command = pl_pause HTTP/1.0', $ 0D, $ 0A, $ 0D, $ 0A "), but the VLC server does not understand this command.
    , Although a one button command "'GET / requests / status.xml? Command = pl_pause HTTP/1.0', $ 0D, $ 0A, $ 0D, $ 0A") perfectly understood
    zaharov wrote: »
    tell me please,
    Control device doesn't work with IP devices.
  • Thanks Vining
    Сan somebody share his ideas to work with VLC?
    I want to write a complete unit of work with this player. I want to implement a control with the touch panel to control not less than the HTML page.
    zaharov wrote: »
    I guess that's my point. But never mind. :/ If you getting the results you need then who am I to argue? :)
    You can kinda accomplish sending something to an IP port by routing it through a virtual device temporarily.
    Sonething like
    define_device
    dv_IP_port = 0:4:0
    vdv_testing = 34001:1:0
    Define_event
    Data_event[vdv_testing]
    String:
      send_string dv_IP_port, data.text
    Command:
      send_command dv_IP_port, data.text
    Then send stuff to the virtual dev in control device.
  • Thank you, Ericmedley
    I'll try,
    Answer, and how to connect virtual device (vdv_testing) with a local port (dv_IP_port)
    zaharov wrote: »
    I'll try,
    There is no need to connect the two devices. (Combine..) By sending a command to the testing device the code will send it on to the port for you. You still have to open the IP port, connect it to something out there and so forth. It's just a work-around for being able to send strings to an IP port.
