DEV Array
                    Hi Guys,
Can someone please tell me if the below is possible and if so why it wouldn't be working?
This is just hypothetical code by the way.
Cameron
DEV dvTelevisions[10]
dvTelevisions[1] = 0:11:0
...etc
DATA_EVENT[dvTelevisions] (tried with [10])
STRING:
SEND_STRING dvDebug,"'DEBUG: TV: ',ITOA(GET_LAST(dvTelevisions))"
Cameron
Define_Variable
Volatile dev dvTelevisions[]=
dvTelevisions1,
dvTelevisions2,
dvTelevisions3
This should have been covered in your programmer class. You can also read the help file in NS and search for Dev Arrays. There are examples of code.
It probably will be, I'm only Programmer 1 atm - got told I shouldn't do higher for at least 12 months, although I already use Timelines etc. meh.
Thanks heaps for the reply, I will do it that way, for some reason I just wanted to do it the dvTelevisions[*integer*] = 0:12:0 way all good but
Thanks again,
Cameron
And don't listen to them about waiting 12 months for P2. Move up when you feel you are ready. Most of what they teach in both classes is simply groundwork, and your real learning is going to happen when you sit down and work on real projects.
I learnt from an old trainer in a one-on-one and have been learning on the job so I have a fairly good grip on a fair bit of it
I guess so, should talk to my boss about getting me in - P1 was good to learn a few things I didn't know about
Plus, it's the only pathway to certification for a new programmer, if you or your boss is interested in that.
Best of luck!
