Connection Status Indicator on G4 panel?
Don DeLong
I've been trying for hours with no luck to get the basic, green/red heartbeat indicator from the setup page on a G4 panel to use on an admin/monitoring page on one of my panels. Essentially, I need a way to show the user that the panel is in fact connected to the master, and the feedback on screen is therefore relevant, and buttons should work.
I've tried using the setup port functions in button properties, but can't seem to get it to function. Lots of searching the forums, but no luck. Any ideas?
Don
Don
1) Copy this button and use it, or
2) Create the multistate bargraph - this button has 11 states. Give it address, channel, and level of 0:8
The panel's operational reference guide should explain what each of the colors mean, but I did not see a tech note on this subject.
Chris
Thanks for your quick response. When I look at the button in TPD4 on the system page template as you suggested, it looks normal on the page: the red/off disconnected looking round button. Selecting the button and looking at state manager reveals it only has 2 states, both of which look the same: A transparent/translucent looking version of the normal connection button. If I copy it to one of my pages, it is just the 2 semi-clear states, and uploading it to a panel which is connected to a master doesn't change its appearance. Any ideas?
Don
Thanks for your help,
Don
