Autopatch Modula Matrix switcher cut off randomly
Had anyone experienced this situation? I have a very simple system, only one autopatch modula switcher,one Tuner source and 1 Ni2100 controller. The autopatch switcher cut off the tuner source randomly, sometimes 3,4 times a day. I was onsite today, had been monitoring the netlinx studio notification log for 2 hours, it didn't not happen, but tonight, the client called, the tuner cut off again when they paying tuner. I check the program, I don't have any command send to the autopatch without button press. when the tuner playing, the autopatch just suddenly cut off the tuner, client had to re-press the tuner button to make it work again, which will send command to autopatch switcher like send_string dvAP, "'CL2I1O2'",in this system, I didn't not use AMX module, only basic command. any idea for this kind of issue? BTW, I changed the tuner, this problem still exist.
Jacky
Jacky
If the problem is in code here are a couple functions you can drop in to create a log that you can look at later on:
// define_function char[60] getFileError (slong slErr) { switch (abs_value(slErr)) { case 0: return '(0) Success' case 1: return '(-1) Invalid File Handle' case 2: return '(-2) Invalid File Path or Name' case 3: return '(-3) Invalid Value Supplied for IO Flag' case 4: return '(-4) Invalid Directory Path' case 5: return '(-5) Disk I/O Error' case 6: return '(-6) Invalid Parameter' case 7: return '(-7) File Already Closed' case 8: return '(-8) File Name Already Exists' case 9: return '(-9) End Of File Reached' case 10: return '(-10) size of DirPath buffer too small for dir path name' case 11: return '(-11) Disk Full' case 13: return '(-13) Directory Already Exists' case 14: return '(-14) Max Num Files Already Open (10)' case 15: return '(-15) Invalid File Format' default: return "'(default) slErr[ ',itoa(slErr),' ]'" } } // define_function integer logToFile (char msg[]) { stack_var slong slDir stack_var slong slFile stack_var slong slResult stack_var char logMsg[200] slDir = file_createdir('\LOGS\') logMsg = "'',date,' ',time,'--> ',msg,10" if (slDir == 0 || slDir == -13) { slFile = file_open('\LOGS\log.txt',file_rw_append) if (slFile > 0) { slResult = file_write(slFile,logmsg,length_string(logMsg)) file_close(slFile) } else { send_string 0, "'<logToFile> Directory OK: File Error[',getFileError(slFile),']'" } } else { send_string 0,"'<logToFile> File Error[',getFileError(slDir),']'" } }You can use the function to log the strings coming from the Autopatch and you can add the line directly above all of you send_string lines for controlling the switcher. I don't know how your code is structured, but there are a lot of places to log a line of info. Like so:
data_event[dvSwitcher] { string: { logToFile('received from Modula[ ',data.text,' ]'") } } // // // logToFile('sending to Modula[ ',cCommand,' ]'") send_string dvModula, "cCommand"Those are just two ideas to get you started. You then read the log by FTPing into the master and opening it in any text editor.
