DVX 2150
kennyann
Are there a lot of issues with DVX2150. I just had an insane number of issues with it. It seems that some of the code I used (which are legacy code) caused the DVX2150 not to soft reboot - I had hard reboot. Even when I put a empty source code - it was doing the same. Please, let me know of any other issues with the DVX 2150. The DVX3150 seemed to be doing better.
When did these start shipping? According to the website they still aren't available.
I have programmed a DVX-3150 with no issues, in fact I loved the simplicity of it.
Technically both units have the same processor and everything else is the same except less ports so The only reason they would behave different would be if the firmware is different, but even that would be identical except for some hardware addresses.
Maybe a pre-production unit accidentally found it's way to you and it's running an alpha firmware.
I think you will need to be more specific with the issues though.
There are a few name changes in the commands between the DVX-3150 and the DVX-2100. I recommend looking at the Operations Reference guides to verify that you are using the correct commands. The DVX-3150 guide contains a list of commands that have changed on page 65.
Jeff Burch
Enova DVX Product Manager.
