Video Distribution with priority of control
MMehta
Hello All,
We are looking for a solution for HDMI Video distribution to 24 zones.
8 Video sources ( 4 Decoder, Apple TV, Media Player, Du TV) all with HDMI connector type.
We are looking for followings functionality :-
1) All the video source need to be distributed to 24 zones.
2) Whoever selects a video source first, control via IR should be disable in other remaining zones.
Everything else is just coding but it sounds like you're looking for a pre-package out of the box solution and that doesn't exist. You first need to find a switcher capable of what you want for the money the customer is willing to spend and that may be you biggest hurdle. Then you need to write a program or hire a programmer to do what you need and that too is also fairly expensive.
Are you at least a programmer? What type of client is this and what's the budget?
Hi Vining,
Thanks for your reply.
Well client is fine with budget, but can we achieve the following functionality as below:
1) Whoever selects a video source first, control via IR should be disable in other remaining zones.
Add 1 transmitter for each source, and behind each tv put a receiver. they recommend cat6 but I have had great luck with existing installs with cat5.
