Reliable Sci Atl Cable Box power control?
Here in Vegas Coz cable is constantly changing things with the firmware on the scientific Atlanta AND Cisco cable boxes. Last I checked, the power-on-with-numeric option had been removed. I was wondering what works better to verify power status on these boxes - a power current sensor or a video sync sensor. I ask this because most of the boxes we work with are DVRs, so the hard drives are always on, pulling power. Thanks.
FYI, The link show a board of 6 relays that snap apart into single boards.
The plug in xfomer 12vdc leads go to the relays control coil terminal and the isolated relay contact terminals go to the IO.
FYI, the IO ports also OUTPUT a small voltage when programatically turned on. Enough current to run those same breakaway relays. So you can use the external relays attached directly to the NetLinx IO ports and get high-current relay action with very little effort.
Here's a good link with IO info.
http://www.amxforums.com/showthread.php?1258-What-are-IO-ports-for&highlight=Signal+diode
