Output decimal number as Binary on a relay card.
Just leaving this here. Got most of it from another thread, so thanks.
I don't like the variable/param/function names, but naming stuff is like the hardest part of programming.
DEFINE_CALL'DECIMAL_TO_RELAY_CARD'(DEV rly, INTEGER iDecimalNumber){
//convert a decimal number into it's binary representation on a relay card
LOCAL_VAR INTEGER itmp64
FOR(itmp64 = 1; itmp64 <=8; itmp64++){
[rly,itmp64] = iDecimalNumber & REL_MASKS[itmp64]
DEFINE_CONSTANT
INTEGER REL_MASKS[8] = {1,2,4,8,16,32,64,128}
define_function fnDec2bin(integer decimalnum) { if (decimalnum & 1) on[dvRelay,1] if (decimalnum & 2) on[dvRelay,2] if (decimalnum & 4) on[dvRelay,3] if (decimalnum & 8) on[dvRelay,4] if (decimalnum & 16) on[dvRelay,5] if (decimalnum & 32) on[dvRelay,6] if (decimalnum & 64) on[dvRelay,7] if (decimalnum & 128) on[dvRelay,8] }Easily modified to make a binary clock in your card cage to impress even the most 1/0 savvy client
DEFINE_CONSTANT INTEGER RELAY_NONE = 0 INTEGER RELAY_1 = 1 INTEGER RELAY_2 = 2 INTEGER RELAY_3 = 4 INTEGER RELAY_4 = 8 INTEGER RELAY_5 = 16 INTEGER RELAY_6 = 32 INTEGER RELAY_7 = 64 INTEGER RELAY_8 = 128 DEFINE_FUNCTION fnRelayOn(INTEGER decimalNum) { [dvRelay,1] = (decimalnum & 1) [dvRelay,2] = (decimalnum & 2) [dvRelay,3] = (decimalnum & 4) [dvRelay,4] = (decimalnum & 8) [dvRelay,5] = (decimalnum & 16) [dvRelay,6] = (decimalnum & 32) [dvRelay,7] = (decimalnum & 64) [dvRelay,8] = (decimalnum & 128) } DEFINE_START // Turn on relays 1, 3, 5 & 7 fnRelayOn(RELAY_1 | RELAY_3 | RELAY_5 | RELAY_7) // Turn off all relays WAIT 50 { fnRelayOn(RELAY_NONE) } // Turn on relays 2 & 4 WAIT 60 { fnRelayOn(RELAY_2 | RELAY_4) }This technique gets a lot of use in the Windows API for passing window flags into API functions, allowing users to pass in any combination of the pre-defined flags.
Oh nice. Maybe I can use this elsewhere...
Personally I prefer your initial version using the lookup table, its simple and neat. Also, as you only have 8 relays to play with (assuming you're talking about the internal ones) this limits you to a single byte rather than an integer.
define_variable constant char RELAY[] = { $1, $2, $4, $8, $10, $20, $40, $80 } define_function setRelayState(char mask) { stack_var char num for (num = 8; num; num--) { [dvRelay, num] = mask & RELAY[num] } }If you're just wanting to represent values and don't care about the convenience of the flag pattern shown by Bigsquatch you can do away with the table altogether:
define_function representValue(char x) { stack_var char num for (num = 8; num; num--) { [dvRelay, num] = x & (1 << (num - 1)) } }Alternatively, if you needed to represent an integer you could do so using both the relays and io's:
define_function showValue(integer x) { stack_var char num stack_var char mask for (num = 8; num; num--) { mask = 1 << (num - 1) [dvRelay, num] = (x >> 8) & mask [dvIO, num] = (x & $FF) & mask } }</procrastination>
I have a pair of these new-fangled EXB-REL8's at the moment to procrastinate with. Actually, this is for a project. I don't know what you all's excuses are.
