Looking for some 4G CF images for MVP-8400
DHawthorne
I just repaired a couple 8400's that had bad CF cards, but my images were 128M and the cards are 8G. They work, but due to the size of the new firmware, I really could use that extra memory. If anyone has an image in the 2-4G range, I'd appreciate it ... would hate to have to send them in for something so easily fixable.
http://www.amxforums.com/showthread.php?8366-Compact-flash-image&p=58129#post58129
Whoops! Sorry mate, that was for the CF card in a master.
To resize the partition on a panel CF card you will need some other software or to boot into Linux.
The easiest way is to download a Ubuntu ISO and use 'Try Ubuntu'.
Then run GParted and resize the last partition.
Let me know if you need any more info.
Cheers
Can you post somewhere the 8400 image to download - thank you very much!
