MXT-1000 Dynamic Image odd
vining
I'm kinda stumped on an odd dynamic image behavior i'm getting on an X panel. My module for squeezebox switches the cover art to grey blank disk or grey radio tower image if the current queue and playing index is empty. When something is queued i get the cover art of the current playing index which displays fine. The grey cd disc or radio tower however does all kinds of freaky stuff. Sometimes the appearance of noise across the image that constantly shifts, sometimes with color variation that look like that last album art bleeding through. Other times it!s multiples of the disc or tower in a kaleidescope affect. Very bizarre and i've never noticed this on any of the non X series panels. In TPD4, dynamic images, the image refresh was zero now ten and dynamo is not checked although the dynamo icon does appear to the left, can't shake it.
I never get a clear image of the disc or radio tower, always broken up.
Can you also attach the physical png file for the tower or blank CD?
Typical local file cover art path:
Typical internet (Rhapsody) cover art path:
The CD and tower are .png images and I can retrieve them if I change the extension to .jpg but the served image is still a png so it's probably something to do with how the MXT processes dynamic png's. I changed the extension in code but when I retrieved the image using IE and went to save it I noticed it was a .png despite requesting a .jpg.
Simon
However, I tried the images you sent and could not reproduce the problem prior to the fix, so I am not able to verify whether the fix will fix your problem. If you are able to reproduce the problem using a static image in the TPD4 resource manager, I can test your pages to see if the upcoming release will fix your problem (if it does not, we will take a second look). You could also wait for the upcoming release and retest.
