Netlinx M2M Communications URL definition
RicardoSiqueira
In a 2 master system. Does it matter in which Master you define the URL Listing? I have a NXF fully loaded and a NI-4100 with less devices. I defined the URL of the 1st Master (NXF) on the 2nd (NI-4100). I know you can only define it on one Master... Would it matter or be better do do the opposite? Master 2 defined on Master 1? Any ideas?
So there is definitely some overhead, and it can be additive. My system that had issues has seven masters, and was definitely happier with all the connections being maintained on a distributed basis rather than being done by the master that had the most going on otherwise.
