Relay's and IO in RMS Enterprise
Have prop. lost my mind but what do i need to do to control REL's and IO's with the new RMS (seemed a lot easier with 3.3 and below) I have NI's and ME's with REL 10 cards. Code snippets or which Manuel to look at ("RMS Enterprise Programming Manual" has no info) would be greatly appreciated.
Thanks for your time
Michael
  • Start with this monitor RmsGenericNetLinxDeviceMonitor.axs.
    You will then need to edit some of the Parameter and Control Method functions to expose the io's and relays.
  • huttencmhuttencm Posts: 23
    Thanks for the reply.
    this is what i got from AMX tech support:
    Adding a New Asset Type
    1. Select Asset Types under Asset Configuration in the Configuration menu to open the Asset Types page
    (see FIG. 356 on page 271). (of Sys Admin guide)
    2. In the Asset Type tab, click the Add button to open the Asset Type Editor dialog (FIG. 358):
    3. Fill in the fields in this dialog to define the new asset type;
    FIG. 358 Asset Type Editor dialog
    The only required entry in this dialog is "Name" and "Key". However, provide as much
    Information
    was told that they would be updating docs for this feature :)
