Tp4 file
mighe
If I understood correctly, a tp4 file is an archive with images, sounds and XML files with page layout... is it possible to "unpack" the tp4 file and access to its resources?
I was thinking to software generate some pages in a batch-way without use the copy/paste way of tpdesign...
Goto Resource Manager (Ctrl + M)
Select Resources and Eport.
1) Not available to any (that I've found) archive software (i.e. WinZip, 7-Zip, WinRar, etc.)
2) Not easily unpackable unless you have the file format.
I've thought about tackling this to make a "delete-only" Explorer type interface to remove those pesky fonts that stick around when you're not using them.
Generating pages would be a whole other story, as the page definition files are in a compressed XML format.
Most often in such cases, a "cease and desist" order. If they can prove financial damage, they can sue for that. I wouldn't expect AMX to pursue either, not in a minor infraction, but that's what other companies have done.
However, I find the entire "what can they do" argument very troubling. Is that what it's really come to? Agreements and promises mean nothing unless you get called on them?
