Hex Command to ASCII
IM trying to send an NEC projector a HEX string for lamp hours. How wold I convert that into am ascii string? Any help is greatly appreciated.
    Well, if you're trying to send a hex string TO something you wouldn't need to convert it to ASCII.
    Just do something like...
    SEND_STRING dv_myDevice , " $05,$AF,$32"
    Or whatever the string.
    A string coming back is going to be a series of hex/decimal values that might mean something in ASCII or not. If its raw hex/decimal/integer data you need then no conversion is necessary.
    But if it is a human-type string ( example: "PWR ON" ) then you'd handle the data as a charactor, not an integer.
  • danlee20danlee20 Posts: 31
    Hex to integer
    Im trying to convert a hex number for lamp hours on an nec. Could I use HEXTOI? I see that you can use HEXTOI. I'm not near my computer otherwise I would try this before asking. I greatly appreciate the help :)
    Post an example of the string.
    danlee20 wrote: »
    It gets complicated as there is no easy way to do this. If your hex number was in ascii format like 'BEEFBABE' then hextoi would work since it takes a character array and gives you an integer. But it sounds like you have a hex number and need a integer so you actually have to change bases. So you end up having to add each hex number up to get the decimal equivalent.
    IE:
    1E5DF
    F = 15 in decimal so (15*16^0) = 15
    D = 13 in decimal so (13*16^1) = 208
    5 = 5 in decimal so (5*16^2) = 1280
    E = 14 in decimal so (14*16^3) = 57344
    1 = 1 in decimal so (1*16^4) = 65536
    Adding all of the numbers together to get the decimal number for HEX number 1E5DF:
    15 + 208 + 1280 + 57344 + 65536 = 124383
    So HEX 1E5DF = Decimal 124383
  • HedbergHedberg Posts: 671
    There is no difference between a hex number and a decimal number as far as the processor is concerned. The only difference is in the human interface representation.
    Therefore, the following declarations/initializations are identical in effect:
    integer dummy1 = $1E5D
    integer dummy2 = 7773
    You can see this for yourself if you run debug and examine values and note that you can select how the integers are displayed to you.
    In other words, there is no need to do any conversion at all to change an integer value from hex to decimal or back -- they are already the exact same thing.
    If you have something that came back from an NEC projector that is an ascii hex representation of an integer, then in all probability hextoi() will do what you need done.
    Thank you for the replies. I am finding the forum to be extremely helpful!!! If you couldn't already tell, I am just starting out. That being said - What I am trying to do is get the HEX response to input to the TP for lamp hours. Im working with NEC tech support to find out which HEX byte(s) I need. Once I have these, can I use a FIND_STRING and REMOVE_STRING command to get the hex byte i need? I imagine I need to do something to the HEX value to make it into a human readable format on the TP?? Thanks
    Ok, I just looked at the protocol for an NEC pa600x projector to see how it responds to a lamp hour request and it appears that it sends a string like:
    "$23,$8C,$01,$10,$10" followed by four data bytes which contain the lamp hour information. Actually, lamp time in seconds.
    So, in order to get your lamp hour string, you would need to capture those four bytes which contain the information you want. There are many ways to do this. (eg: mid_string(sString,6,4))
    Then what you have is a 4 byte string of integers that you have to decode. Probably they are in reverse order with the least significant byte first. Here is one way to do this assuming that you have captured the lamp hours to a 4 byte string with least significant byte first:
    clear_buffer sLongString
    for(i = 1; i < 5; i++)
      sLongString = "sLongString,itohex(sHexString[5-i])"//sHexString is the 4 byte string extracted from the response
    long_LampSeconds = hextoi(sLongString)
    That is, convert the integer bytes that are returned from the NEC to their ascii hex equivalents while reversing the byte order. Then, use hextoi to convert to one long_integer. In the case of the pa600x (and some other NEC projectors) lamp time is in seconds. You need to use long (32 bit) integers and if you want hours, divide by 3600. Then, use itoa to get hours as ascii decimal to send to your touch panel.
    Hedberg wrote: »
    I don't think you get an ascii hex representation from NEC projectors for lamp hours but I could be mistaken about that. I think what comes back if you use 281 as an example, is a hex number of $01$19. The hex number $01$19 is 281 in decimal but using your code you would get 401.
    a_riot42 wrote: »
    What you are going to get back from the NEC is a string of 8-bit bytes. In your example, you have a 2 byte string:
    sLampHourString = "$01,$19"
    Probably the easiest way to convert that string into the integer it is supposed to represent is to use the bitwise LSHIFT operator:
    nLampHours = sLampHourString[1]<<8 + sLampHourString[2] //281 in decimal
    if the string were (as in your previous example) three bytes:
    sLampHourString = "$01,$e5,$df"
    then
    nLampHours = sLampHourString[1]<<16 + sLampHourString[2]<<8 + sLampHourString[3] //124383 in decimal format
    edited to add:
    My previous suggestion about using itohex and hextoi is pretty boneheaded, though it does work.
    This has been covered before, probably more than once. Here is an example with respect to one of those insufferable Barco projectors which seem to code lamp time in a similar format to what NEC does:
    http://www.amxforums.com/showthread.php?8232-Barco-Hex-Conversion
    Just have to make sure whether the bytes are most significant or least significant first.
    Hedberg wrote: »
    Yes a string is all you can get in a data event, but I prefer to not think of the bytes as strings but instead simply a bitstream that can represent characters, numbers, images, etc. I think the confusion occurs when people think that because its a string, its a bunch of characters, which it really isn't in this case, since its an integer in base 16. 0x119 is not equivalent to "$01,$19" even though they both look like hex, which I think is where people get confused and that was the point I was trying to make with my summing algorithm. You can implement the summing algorithm by bitshifting left as you mentioned, although it wouldn't surprise me if the compiler optimizes any multiplication by a power of 2 behind the scenes anyway so either bitshifting or multiplying by powers of 2 (0x10, 0x100, 0x1000) would result in the same machine code. You have to worry about truncation too so it can get ugly.
