XCH droping the first digit
Hello, I am facing a strange problem with an NI3100 FW v3.60.453
I don't know why XCH drops the first digit
example:
any idea, I tried to change all XCHM patterns but I get the same result
regards
m.
example:
send_command dvIr, "'XCH822'"; //will send 22
regards
m.
Edit:
Also, make sure the integrated device (5001) also has the latest firmware. Current version is 1.30.8.
Thank you, don't know how I couldn't figure out the space
problem fixed
Am sure about the NI3000 but I don't know which firmware the NI3100 has before I upgraded
I'm guessing any old thing will work as long as there is one throwaway character after XCH and before the number. It looks like it uses an absolute position. Not a bad way to ensure backwards compatibility if the format changes.
Older firmware may have worked. From the release notes for firmware v1.20.7:
So they changed it and fixed it. So either might have been to add ignoring the space.
