Home AMX Technical Discussion
XCH droping the first digit
Hello, I am facing a strange problem with an NI3100 FW v3.60.453
I don't know why XCH drops the first digit
example:
send_command dvIr, "'XCH822'";   //will send 22
any idea, I tried to change all XCHM patterns but I get the same result
regards
m.
  • The command should have a space between 'XCH' and the channels, so my guess is it's throwing away the 8 assuming it would be the space:
    send_command dvIr, "'XCH 822'";   //should send 822
    Edit:
    Also, make sure the integrated device (5001) also has the latest firmware. Current version is 1.30.8.
    Thank you, don't know how I couldn't figure out the space :)
    problem fixed
  • Note: In older firmware or in NI3000 XCH822 was working fine
    Am sure about the NI3000 but I don't know which firmware the NI3100 has before I upgraded
    Also, XCH-<number> works.
    jjames wrote: »
    I'm guessing any old thing will work as long as there is one throwaway character after XCH and before the number. It looks like it uses an absolute position. Not a bad way to ensure backwards compatibility if the format changes.
  • moty66 wrote: »
    Older firmware may have worked. From the release notes for firmware v1.20.7:
    AMX-PI wrote:
    - Support for XCH command for 4 digit channel. New XCH modes 5 & 6
    added. These are equivalent to the current modes 1 & 2 except.
    for 4 digit channel numbers.
    - Fixed some issues with XCH command.
    So they changed it and fixed it. So either might have been to add ignoring the space.
