Old web interface
carrizt
I am new to using NetLinx Studio so please forgive me if this is question is too basic for this board.
I have several classrooms that use this old web interface as the only UI, so if it locks up it can cause major problems. I’ll be upgrading everything over the course of the next few months, but I want to use the same GUI. How can I get the .tpd (web interface) files off of the amx controller (mostly NI-2100)? I can pull the source codes fine using NetLinx Studio, but when trying to get .tpd files it times out. It actually does create a file, but it is empty. Do I need to point to a different device number?
I recently uploaded a webpage to a DVX3155, which is a fairly new controller if you ask me
The only thing I've seen that semi-reliably works on the web panel is if you keep everything on one page and this only if you don't put any graphics on it. Just plain buttons with plain text. The bottom line is that it's not supported and will probably some day go awy. I would not plan on using it on any new systems myself. You just have no guaranty that it will work.
The latter posts were in response to Yuri I think.
Yes John, this is exactly what I was asking. I had a feeling this would not be possible, but had fingers crossed.
Thanks.
Yeah, I heard that some years ago too. We're keeping an old TPClasses.jar file just to keep things working for one customer
I have this DVX 3155 with 1 dxlink receiver connect and 1 dx link transmitter, I found out that a bluray can pass to DXlink but it does not on HDMI out, any thoughts,,,Blurayis connected to HDMI input
