How to access master from Command line?
in AMX Hardware
Sorry, I'm suffering from brain fog!
What is the procedure to access a Netlinx master from the cmd line?
I am trying telnet\192.168.1.11 1319 etc. and not making it!
I need to change ports for a multiple master setup.
Also, can you only change the ports via IP or is possible via serial connection?
Or, you can use a program like PuTTY and click on the telnet radio & make sure that the port is 23 (default.) Port 1319 is for ICSP connections.
You can change connection ports via IP, terminal or the master's webpage.
