IS-SPX 1000 & 3G
tical1969
Hello
Does anybody has ever installed an IS-SPX 1000 with a 3G Connection
What is needed (else than a player and a key 3G)
How to ?
Regards
Alexandre.
How to ?
Regards
Alexandre.
The biggest difficulty i found was that most 3g keys have a built in router so the IP address it assigns your SPX is a private address so remote connections must be initiated by the player.
This means i could only get content into the player by setting it in pull mode, i couldn't just push content in whenever i felt like it.
Apparently it is possible if you get the ISP to set up a VPN, at his point i decided that a regular adsl modem is much easier.
Dave
honestly, the best approach nowadays is to get a 3G or 4G router. that way you can have the player connected to the router allowing you to configure port routing to access that player from anywhere.
https://www.google.com/webhp?sourceid=chrome-instant&rlz=1C1CHWA_enBR620BR620&ion=1&espv=2&ie=UTF-8#q=4g+router&tbm=shop
