I am a happy programmer and doing a good job - a Little Off Topic
I need some help gathering some data. Could the group please take a survey
about AV system programming. Pretty Please.
http://www.surveymonkey.com/s/BDFC9D8
If you are asking questions like this I think you are not happy.
Programming Happyness
1. What types of systems do you program most?
Commercial AV Systems
Residential AV Systems
Other (please specify)
2. Do you feel that your programs are complete when the customer takes possession?
Yes
No
Almost
3. Do you ever leave bugs in your system with the idea of "I'll get around to fixing it" or "the customer will never run into it"?
Yes
NO
4. Have you ever chosen to program a solution one way knowing there's a better method?
Yes - Please put you reasons in the comment box.(Example: Time, I don't know how, Etc)
No
5. Do you skimp on your programming due to project constraints?
YES
NO
6. How long have you been programming?
7. Do you feel that AV System programmers are up to par with where they should be.
YES
NO - Explain
8. Do you feel that programmers limit features because of complexity in programming?
YES
NO
YES and this is why
9. Are you happy with the programs you turn over?
Yes
No
YES and NO, I Wish (please specify)
10. What do you think could make the industry better?
Glad I'm not the suspicious type.
You are 80% right.
You are correct sir!
