Sennheiser Media Control Protocol for ew300/500 receivers
Hi,
Has anyone experience using the Sennheiser Media Control Protocol for readout settings ie. battery level etc for a Sennheiser ew300 series receiver?
I have the protocol from the sennheiser site but I won't get any response.
I make a connection using UDP (type 3 in IP_CLIENT_OPEN) over port 53212.
Regards,
Hans Schouten.
  • Please do not cross-post threads.
    You have already posted this here: http://www.amxforums.com/showthread.php?9285-Sennheiser-Media-Control-Protocol-for-ew300-500-receivers.
    As Auser once put it:
    Auser wrote: »
    Spawning multiple identical threads for a single question such as you've been doing is considered poor forum etiquette and could mean that people won't answer your questions if they do have information which could be of help to you.
    If somebody hasn't answered your initial post, it could well be because we can't offer advice based on the information you've given.
    If nobody responds and you're desperate for an answer, post another message in the same thread you started providing more information on your situation instead of just posting the same question over and over in new threads. Posting code you've already written and the protocol for the device/application that you're having trouble with generally helps us to help you. The more information you provide, the more likely it is that we'll be able to help.
