RUNCO VX2C Module
For some reason the module doesn't compile? This is from the UI mod:
(*               CONSTANT DEFINITIONS GO BELOW             *)
POWER_ON_BTN = 1
POWER_OFF_BTN = 2
IS_COMPOSITE_BTN = 3
IS_SVIDEO1_BTN = 4
IS_SVIDEO2_BTN = 5
IS_COMPONENT_BTN = 6
IS_HD1_BTN = 7
IS_HD2_BTN = 8
IS_DVI1_BTN = 9
IS_DVI2_BTN = 10
IS_CYCLE_BTN = 11
AR_ANAMORPHIC_BTN = 12
AR_NORMAL_BTN = 13
AR_LETTERBOX_BTN = 14
AR_WIDESCREEN_BTN = 15
AR_CYCLE_BTN = 16
PRESET_NIGHT_BTN = 17
PRESET_DAY_BTN = 18
PRESET_CUSTOM1_BTN = 19
PRESET_CUSTOM2_BTN = 20
WARM_COOL_BTN = 21
BRIGHT_UP_BTN = 22
BRIGHT_DN_BTN = 23
CONTRAST_UP_BTN = 24
CONTRAST_DN_BTN = 25
COLOR_UP_BTN = 26
COLOR_DN_BTN = 27
TINT_UP_BTN = 28
TINT_DN_BTN = 29
SHARP_UP_BTN = 30
SHARP_DN_BTN = 31
DATA_INITIALZIED_BTN = 32
DEVICE_ONLINE_BTN = 33
BRIGHT_LEVEL = 1
CONTRAST_LEVEL = 2
COLOR_LEVEL = 3
TINT_LEVEL = 4
SHARP_LEVEL = 5
WARM_COOL_TXT = 1
BRIGHT_TXT = 2
CONTRAST_TXT = 3
COLOR_TXT = 4
TINT_TXT = 5
SHARP_TXT = 6
#INCLUDE 'SNAPI.axi'
(*              DATA TYPE DEFINITIONS GO BELOW             *)
DEFINE_TYPE
Then there's:
CHANNEL_EVENT[vdvDEVICE, LAMP_WARMUP_COOLDN_FB]
	ON:
                ....... and so on..............
But the constant LAMP_WARMUP_COOLDN_FB isn't defined any where. Actual if you look above we have no constants just devices defined.
I looked in the Word Doc and I think the value that should be assign to LAMP_WARMUP_COOLDN_FB if it were deifined should be 253 but I'm not all that sure. The value isn't set anywhere that I can see so it must assigned in the com module. Although I defined the constants as constants and define LAMP_WARMUP_COOLDN_FB with the value of 253 I still get no feedback at all from comms. The module does control the Proj/processor and I get strings returned but I'm not sure what the comm module is doing cuz the ain't nothing coming out the back end.
I really don't want to write it from scratch especially since it's to be operational by Tuesday and there are other things I was planning to do.
Maybe if this new Duet module wasn't on the website months ago when I looked I would have written one myself when I had time but now that the projector just got installed and I had a chance to slap in the module I get bitten once more. When am I going to learn! I don't mind so much when a module has quircks but how can they put this out to programmers when it can't even compile on its own. Let alone work properly!
    Still don't get any feedback and in diagnostic there's some sort of Duet Java exception thrown. I was looking further at the DATA_EVENTS and the UI module is sending commands to the virtual device comm module via SEND_COMMANDs and the UI has a COMMAND event handler to recieve strings from the COMM mudule which normally would be a STRING_EVENT handler so I switch it around and still not a peep from the COMM module.
    I sent STRING & COMMAND "PASSBACK" to the virtual and nothing. So I'm starting from scratch. The Runco protocol for sending to the device is very straight forward via 40-50 commands but they don't specify anything about a returned format. Nothing to tell me what I should expect from the Projector/Processor when I send it a command or query. OK, so I set up a DATA_EVENT handler and buffers and alll that, opened up notifications to watch what's getting passed back and forth but I don't see any logical structure to what the device is replying with. I thought I could just send a command or query and see what it responds with but I can't make heads or tails out of it. F.....!
    Any body got a more detailed protocol for this thing or possibly a working module. Hopefully it's just cuz I'm aggrevated that I can't see any sense in the returned strings and when I start fresh tomorrow it will be perfectly clear. Or not!
    The actual Runco protocol is extremely simple; I have been using variations of the same module for all Runco projectors for years. Here is the VX-2C version, field tested and in use; it should be fairly easy to adapt if you need to add more than the basic functions I already have in there (power, input, and aspect control). The manual from Runco is included, protocol in the back.
    Thanks Dave! I'm almost done with my version and I agree the send command protocol is very straight forward. I just haven't figured out how to figure out what it's sending back. I know -> is bad command received and +> means good but the other stuff has me presently confused. Especially the queries!
    Line     13 :: VXC2 DEV:5001:2:1, Mod Rcvd:  A$09$0D$0A16:9$0A$0D+> . <-Line-<289>$0D$0A - 10:45:00
    Line     14 :: VXC2 DEV:5001:2:1, Mod Rcvd:  A - 10:45:26
    Line     15 :: VXC2 DEV:5001:2:1, Mod Rcvd:  A$0D$0AAnamorphic$0A$0D+> . <-Line-<289>$0D$0A - 10:45:29
    Line     16 :: VXC2 DEV:5001:2:1, Mod Rcvd:  V$08$82$0A. <-Line-<289>$0D$0A - 10:45:57
    Line     17 :: VXC2 DEV:5001:2:1, Mod Rcvd:  V$08$82$0A+> . <-Line-<289>$0D$0A - 10:45:57
    I'll look at your module for help. I also found a newer protocol on the Runco site which now let me control the 2.35 virtual wide.
  • Runco VX2C Module
    Thank you for the module. I am a little unclear on how to interface the the touchpanel buttons. Can you clarify for me?
    Erik
    eriklhayes wrote: »
    Erik
    I don't generally incorporate the UI within my device modules. It's strictly command line to the virtual interface, and the main program handles buttons and uses SEND_COMMAND to the virtual to trigger actions. Projector states are passed back as channels on the virtual device (input, aspect and ISF), and the virtual also uses a SEND_STRING to pass back the lockout (which is my way of showing the projector is warming or cooling and the interface won't accept power commands).
