Modero 8400 Jammed in Wall Docking Station
davegrov
I received a call from an out of town client who can not remove his 8400 from the Wall Docking Station. He is getting power to the unit but not getting any response from the WDS. I do not think he uses the stylus, but am aware it could be not seated properly.
Does anybody have a method to remove the panel without damaging the panel, the WDS or wall?
Thank You in Adavance
David Groves
DG Sales and Service
David Groves
What sort of plastic? Something like a relatively stiff plastic ruler or something about the stiffness of those plastic flow chart templates that we used to use before the age of visio.
The way the story goes is that the snap holding the panel in the dock needs to be bumped towards the top of the panel. So, what you need is a plastic ruler (or similar) with a cutout which can be hooked around the snap and used to pull the snap upwards.
We had one of these about a year or two ago and I was working on a solution, but one of the guys with the screwdrivers and soldering irons attacked the problem with a lot less subtlety and I never got to try it out. We should be happy that they don't have hammers.
