All buttons event??
I need to keep a popup "visible" while ANY button on the interface is pushed, and hide the popup when no button is pushed (in a few seconds).
So, my question is:
Can i make a "push" event for ALL buttons at all ports and channels of the touch pannel interface?
If not, do you imagine a solution for what i´m trying to do?
Thanks!!!
So, my question is:
Thanks!!!
Dev tpsAll [] =
tp1, tp2, tp3, tp4, tp5
BUTTON_EVENT[tpsAll, 0]
//Show Popup
DEFINE_VARIABLE Dev tpsAll [] = { tp1, tp2, tp3, tp4, tp5 }; DEFINE_EVENT BUTTON_EVENT[tpsAll, 0] { PUSH: { //Show Popup } RELEASE: { CANCEL_WAIT 'SOME_WAIT_NAME'; WAIT SOME_TIME_CONSTANT 'SOME_WAIT_NAME' { //hide pop up } } }You could forget the release altogether and put its code in the push too. Might even create a flag to track the pop up and then if(nPopUp_Closed) call to open the pop up an then when you open it set nPopUp_Closed to 0 and to 1 when you close it, just to reduce the number of commands to the TP.http://www.amxforums.com/showthread.php?5943-EVENT-TABLES&highlight=Button+event+0+catch
I´m going to try your code.
Really appreciate your help.
