ICSPTCP End ???
jsnyder
Greetings,
I've been undergoing a rash of TP disconnects with no clue as to why. the NI controllers stay online but the TP's (CV10's and 1000vi's) appear to randomly lock up requiring a minion to be dispatched to which ever of the 51 classrooms this occurs in. The issue has gotten so bad I have rewired all of the TPs power through an unused relay on the controller so i can reboot them from my "Omnipanel".
Here is a sample of the log from a locked panel.
2: 02-22-2013 FRI 08:33:58 MasterUrlConnect
Connected to (Sys=3) Master 1XX.21.200.113 (URL Mode)
3: 02-22-2013 FRI 08:33:49 SocketClosure
ICSPTCP End
4: 02-22-2013 FRI 08:33:41 MasterUrlConnect
Disconnected from (Sys=0) Master 1XX.21.200.113 (URL Mode)
5: 02-22-2013 FRI 08:33:41 SocketError
ICSP TCP Socket read error: iBytesRead==0
6: 02-22-2013 FRI 08:32:26 SocketError
Socket connect attempt failed: No route to host (errno=0x94)
7: 02-22-2013 FRI 08:32:20 SocketError
8: 02-22-2013 FRI 08:32:15 SocketError
9: 02-22-2013 FRI 08:32:09 SocketError
10: 02-22-2013 FRI 08:32:04 SocketError
11: 02-22-2013 FRI 08:32:01 SocketError
12: 02-22-2013 FRI 08:31:55 SocketError
13: 02-22-2013 FRI 08:31:50 SocketError
14: 02-22-2013 FRI 08:31:02 SocketClosure
ICSPTCP End
15: 02-22-2013 FRI 08:30:54 MasterUrlConnect
L Mode)
79: 02-22-2013 FRI 07:53:30 SocketError
80: 02-22-2013 FRI 07:52:05 SocketClosure
ICSPTCP End
81: 02-22-2013 FRI 07:51:57 MasterUrlConnect
82: 02-22-2013 FRI 07:51:57 SocketError
ICSP TCP Socket read error: Connection reset by peer (errno=0x83)
83: 02-22-2013 FRI 07:50:33 SocketClosure
ICSPTCP End
84: 02-22-2013 FRI 07:50:25 MasterUrlConnect
85: 02-22-2013 FRI 07:50:25 SocketError
FRI 08:25:49 SocketError
Socket connect attempt failed: Connection timed out (errno=0x91)
23: 02-22-2013 FRI 08:22:40 SocketClosure
ICSPTCP End
24: 02-22-2013 FRI 08:22:32 MasterUrlConnect
25: 02-22-2013 FRI 08:22:32 SocketError
26: 02-22-2013 FRI 08:21:31 SocketClosure
ICSPTCP End
27: 02-22-2013 FRI 08:21:23 MasterUrlConnect
28: 02-22-2013 FRI 08:21:23 SocketError
29: 02-22-2013 FRI 08:20:33 SocketClosure
ICSPTCP End
Any thoughts?
Thanks in advance for any help.
John
ICSPTCP End
ICSPTCP End
L Mode)
ICSPTCP End
ICSPTCP End
ICSPTCP End
ICSPTCP End
ICSPTCP End
Any thoughts?
John
http://www.techdirt.com/articles/20130217/18381022008/attribution-troll-press-inc-now-50-less-troll-like-also-not-yelling-people-sells-more-books.shtml
Things to try (as suggested by tech support):
disable bonjour on the TP if the panels have this feature
Use static IP addresses, set ethernet mode to full, 100 (or 10 or something) on masters and tps
Disable zeroconfig on the masters
Disable UDP on the masters (baud rate to zero)
Disable SSH on the masters (port set to zero)
all other settings were as suggested (I've been reading posts trying to resolve this for sometime)
now we wait and see.
Have a splendid weekend.
John
had a panel drop after turning off ssh
Recently had indentical problem (all panels were on static LAN IP) on site, network switch (D-Link in my case) was the reason of this problem. The new switch (Netgear) solved this problem.
For test you can use any 5 (or 8 port) switch, connect controller and some panels. If it helps, the problem is network switch.
VLad.
We'll try this and let you know.
Thank you.
John
from a controllers log:
19: 03-13-2013 WED 02:12:36 Interpreter
CIpEvent::OffLine 10001:1:1041
20: 03-13-2013 WED 02:12:36 ICSPTCP
ICSPTCPRx1::CloseSocket: Closing Socket
and the touch panel never regains its IP.
For goodness sake! will some linux hacker out there write a new firmware for cv-10's and 1000vi's
so they agressivly regain their IP after a loss?
oh yeah,
PLEASE
thanks
John
Sounds like he might have "seen" it on HIS network not realizing it was valid he locked it out??
Our infrastructure varies from building to building. yesterday 10 classroom touch panels lost their IPs while the controllers and other devices were fine, all on a older commercial switch (HP400).
today its 8 panels dropping IPs in another building thats only 2 years old. multiple reboots of panels required.
arg!
John
No, it was really locking up. For one, the touch panel, though reachable from the outside via VNC, can't see the master on the house network. For two, I keep persistent logs on my masters, and the module is set to delete logs more than 5 days old (which I can set to whatever I want, but this guy was 5). There were no logs on the master except the current day, which tells me it was not recording for 5 days and when it rebooted, the old ones were all deleted.
But to get back on topic, since the same flaky master works on *my* network, I can't help but think a noisy network environment is part (and probably only a part, since a new master fixed it) of the problem. I once had a master that was locking up like this 2-3 times a week, and I was pulling my scant hair out trying to find it (there's a big long thread on it in here), and that time a new master *didn't* fix it. It fixed itself. It just suddenly started working just fine, thank you, and has been for over a year. I strongly suspect there are things going on that the AMX devices don't like, but aren't vocal about either ... my logs never show much of anything except what you are seeing: something going off line, no idea why.
On new jobs, I use a managed network switch, and insist the customer upgrades the network as part of the job. I make sure I have a VPN router, and I divide the system into subnets so my control stuff has it's own network. Only time will tell if it's a complete solution.
Hi
AMX is not very "open" in explaining those non-documented meesages in the logs.
I have a project with 25 android panels + TPC license. They are continuously going offline and online. Cisco AP's. Tried other AP's, hiding SSID, changing channels, etc etc ...
PC's connected wireless to the same isolated network never have an issue.
The panels have just a displaying function, so I left it like it is
I had years ago a project where everything was nicely controlled and integrated on the network of the customer, a big telecom operator. For one or other reason, after a while the http and telnet part of the NI crashed.
I had the feeling at that time that the NI's don't like too many requests on their NIC (like ARP etc etc).
We created and moved them to a dedicated multimedia VLAN and things were solved.
We were the only 3thd party contractor with gear on their network they had to do that for and I can tell you that it was the last time we sold amx to them.
Numerous times I did the effort to give feedback on the java problem with NI controllers.
I.e. when you browse to the NI with a browser that has the latest version of java, the probability is high that the webbrowser in the NI will crash after a while.
Only remedy is rebooting the NI, but when the facility is in use at that moment, ...
So I proposed to foresee a function or command to reboot only the webserver via f.e. telnet.
I can understand that amx cannot foresee that every NI with older firmware is compatible with the latest java version, but amx ... foresee "something" without having to reboot the NI.
Another project.
48 rooms, 37 NI controllers
After an NI is rebooted, webserver and telnet crashes after 2 to 8 hours.
Also here investigated many hours together with network experts of the customer without resolution.
Also here we are the only vendor with that kind of problem.
But keep on smiling all ... the only way is up
best regards
Mike
This same behaviour occured in touch panels occasionally too.
It's kinda scary to hear that it seems to be back...
The controllers stay online, but the silly panels are still going off and online like nuts..
get to the panels setup and go to the "System Settings" page and within 10 seconds it rejoins the network..
