TP4 importing images
always-learning
If you import an image into a TP4 project where is it stored? I assume it is not attached to the TP4 project you are working on. Can you delete imported images as I have lots of old ones I no longer use.
Just by way of additional comment that might be helpful, don't try to delete a hundred images at once; it's a heck of a lot easier if they are in use to just delete the a smaller bunch at a time, note the ones in use, and try again.
