Zone wise merging for HVAC,Lights,Audio and Video via Structures
I inherited a project where the previous programmer used structures to divide hvac, audio, video and lights. So different rooms will have an id for a structure named Locations.
Now the client wants to merge dressing room and bathroom to a single zone but since the code is very complex and vast. I am able to merge video but audio, hvac and lights is having an issue.
I can't really make heads or tails of it myself. Its not often I see code like this:
This code was not meant to be easily editable from what I can see. There's a function called join_locations, so maybe you can use that, but its not obvious what it does. Normally merging two zones shouldn't that be a big deal. You've definitely got your work cut out for you that's for sure.
