Datavideo SE-500
Does anyone have experience controlling one of these devices? I just looked up the protocol and it's a bit convoluted and unclear. I was hoping someone would have the basics coded (e.g. "Select Input 1") so that I wouldn't have to spend a few hours decoding the control protocol and then playing trial-and-error with the code.
Thanks!
Thanks!
Hi
Do you have the control protocol? I am having problem figuring out with the checksum
define_function char CheckSum(char _cCommand[]) { stack_var integer _nCharacterIndex stack_var integer _nBitIndex stack_var char _cCheckSum for(_nCharacterIndex = 1; _nCharacterIndex <= length_array(_cCommand); _nCharacterIndex++) { for(_nBitIndex = 0; _nBitIndex < 8; _nBitIndex++) { if(_cCommand[_nCharacterIndex] & (1 << _nBitIndex)) _cCheckSum++ } } return _cCheckSum }
