Home AMX Technical Discussion
Panasonic TH-55LRU50 protocol
Does anyone have the protocol doc for this Panasonic plasma display?
I thought it was like the other Panys but we cant control input selects even though power control is just fine.
Thx.
    I've only done Panasonics IR ... but I do recall not having discrete input commands. I had to press the Input button, then a number to pick which input. Not sure if that helps you or not, take it for what it's worth.
    Every doc I have says the same thing
    Input select is:
    IMS:***
    where *** is one of these:
    (SL1,SL2,SL3,PC1, None) another doc has (SL1,VD1,YP1,HM1,DV1,PC1)
    Does the input query work?
    QMI
    Try it and see what it returns and if it does return something manually change the input and query again until you've received all the possibilities.
  • This duet module works 100% on the TH-37LRU50
    Panasonic_TH50PZ850U_Comm_dr1_0_0.jar
