Page Commands: Previous Page?
Since I've never seen this documented I assumed it just wasn't possible or I just couldn't find something that was obvious to everyone else. Today I again wanted that functionality in my code and looked in PI once more and still found nothing so I decided to try >diagnostics>control device, send_command>"'PAGE-'" to my TP and it worked like a charm. So sending PAGE- with out a page name effectively works as TPD4 "previous page - n/a".
Has this been public knowledge for the last 10 years and I've just had my head up my a$$ or what?
    For what it's worth, I never heard of it.
    trobertstroberts Posts: 228
    Nice tip thanks for sharing!
    viningvining Posts: 4,368
    DHawthorne wrote: »
    Hmmm, I wonder if this is just an advantageous bug then? With my luck I'll use it as previous page: n/a and then a firmware change down the road will fix it. I never understood why there wasn't a command for it and I did a couple of forum searches on the subject and I wasn't able to find any previous members asking why it wasn't available either.
    I'm almost afraid to use it now for fear it will bite me in the a.. later. :(
    Any AMXers out there have an input? Will "'PAGE-'" with out any name continue to work as TPD4 previous page: n/a does or might this change with out notice. And while you're here why don't we have that feature as a documented command anyway? Seems a like a fundamental feature to provide.
    gsmithgsmith Posts: 59
    It was a bug. The feature will be supported going forward and we'll get it added to future documentation.
    gsmith wrote: »
    Just goes to show that some bugs are good. Thanks for the feedback and not sqaushing this beneficial bug.
    AuserAuser Posts: 506
    So is there another bug that allows you to go forward a page using 'PAGE+' if you've gone back a page using the 'PAGE-' bug? :D
    the8thstthe8thst Posts: 470
    gsmith wrote: »
    Can we add a request for a "TOGGLE POPUP" command through code then? Why not shoot for the moon, right?
    the8thst wrote: »
    Have you ever tried this:
    "'PPOG-<popup page name>;<page name>'"
    Toggle a specific popup page on either a specified page or the current
    page.
    If the page name is empty, the current page is used (see example 2).
    Toggling refers to the activating/deactivating (On/Off) of a popup page.
    This command works in the same way as the 'Toggle Popup' command in TPDesign4.
    vining wrote: »
    I have searched PI for that command on multiple occasions. I guess I didn't search well enough.
    the8thst wrote: »
    I find PI to be extremely frustrating to find information in. Half the time I go to look for what a SEND_COMMAND syntax is, or what other commands are available for a device, and all I get is the revision history.
    DHawthorne wrote: »
    Yeah, I think I'd prefer a big text file or Excel spreadsheet that I could just do a quick seach sometimes.
    the8thst wrote: »
    Don't feel bad, I just happen to know it was there since prior to starting this post I went through all the page commands again for probably the 100th time looking for a command to simulate TPD4's previous page:n/a. It's only because I wasn't looking a pop up toggle command that I found it and fortunately I remembered seeing it. If I was looking for it, it could have bit me in the a ss and I still wouldn't have found it.
