DVX System- First Install what to lookout for
livewiresi
in AMX Hardware
Hello All,
We were hesitant to try... now we are finally doing it. I have faith..(or should I ) Our programmer has done a handful and is confident in that regards... however everything the first time isn't always fun. Is there anything to do right out of the box that could save some time?
We are going to be using a 6x3 DVX and the config is basic...
Sources will be.
Cable HDMI
BluRay HDMI
LifeSize HDMI
2 Table inputs using AVB-TX-MULTIDXLINK transmitters
1 Local Rack PC
One Display using AVB-RX-DXLINK-HDMI receiver
Display Audio no additional speakers
We truly appreciate any insight or suggestions.
Thanks so much!
Sources will be.
Cable HDMI
BluRay HDMI
LifeSize HDMI
1 Local Rack PC
Thanks so much!
Second this, also there are commands you have to send to the DXLink ports to enable ethernet to pass along them so you can control the transmitters and receivers. I think the latest firmware notes say they finally fixed it so you only have to send those commands once, but last time I did a system those commands needed to be resent on every reboot.
Also, make sure you set the dip switches on the transmitters and receivers to match your application before you put them somewhere hard to get to/check.
