Denon BluRay protocol
Has anyone used a Denon 2012UDCI BluRay player? I am having trouble directly selecting a Track or Title using RS232.
I can play, stop, pause and other functions but direct track select does not work.
I downloaded a file posted by Tonyangelo but it does not include direct track selection.
Any ideas?
Thanks.
Any ideas?
Thanks.
You might want to post the code you are using to do a direct select. From what I recall you have to insert the selection into the command using the ascii value.
Track: 02,4C,32,x1,x2,x3,x4,03
0-9999
Where x1 = 1000 digit
Where x2 = 100 digit
Where x3 = 10 digit
Where x4 = 1 digit
source
mode
disc layer
Any idea on these commands?
I was using $03 as the track number to get to track 3. Changed it to $33 and all is well.
Thanks.
