Help needed parsing strings from GE alarm panel
I am trying to communicate with a GE alarm panel, model NX8E, using their virtual keypad accessory, model NX 587. We are using an NI-4100.
All of my commands to the alarm panel are working correctly however I'm having trouble properly interpreting the strings returning from the device.
I began by connecting my laptop to the virtual keypad device and here is what it looks like in HyperTerminal:
This conforms with the instructions given for the virtual keypad. The trouble I'm having is the strings look like this to the NI-4100:
It seems like the NI-4100 isn't properly reacting to the Line Feed character. Since the incoming lines don't begin with the data I was expecting, I was having trouble figuring out how to parse these strings to get the information I need. Do I need to change something in my Netlinx code to fix this? If this is just the way it is, any suggestions on how to extract the useful info from the chaff?
Anyone have experience with this alarm configuration and have any helpful tips?
Shane
DL1System Not Ready DL2For help, press~ DL1Service Required DL2Type *2 for help DL1System Not Ready DL2For help, press~ DL1Service Required DL2Type *2 for help LDS-r-p LDF---b- BZ0 PA1Rasceeps PA2Rasceeps
Line 96 (15:27:12):: String From [5001:7:1]-[$0ALR1$0D$0ADL1 System Ready $0D$0ADL2Type code to arm$0D$0APA1Rasceeps$0D] Line 97 (15:27:26):: String To [5001:7:1]-[1$0D] Line 98 (15:27:29):: String To [5001:7:1]-[9$0D] Line 99 (15:27:32):: String To [5001:7:1]-[8$0D] Line 100 (15:27:34):: String To [5001:7:1]-[4$0D] Line 101 (15:27:35):: String From [5001:7:1]-[$0ALA1$0D$0ALE1$0D$0ADL1 System Armed $0D$0ADL2Zone(s) Bypassed$0D$0ABZ3$0D$0APA1RAs] Line 102 (15:27:35):: String From [5001:7:1]-[ceEps$0D] Line 103 (15:27:37):: String To [5001:7:1]-[4$0D] Line 104 (15:27:37):: String From [5001:7:1]-[$0ALR0$0D$0APA1rAsceEps$0D] Line 105 (15:27:42):: String From [5001:7:1]-[$0ALR1$0D$0APA1RAsceEps$0D] Line 106 (15:27:52):: String To [5001:7:1]-[1$0D] Line 107 (15:27:58):: String To [5001:7:1]-[9$0D] Line 108 (15:28:02):: String To [5001:7:1]-[8$0D] Line 109 (15:28:04):: String To [5001:7:1]-[4$0D] Line 110 (15:28:05):: String From [5001:7:1]-[$0ALA0$0D$0ALR0$0D$0ALE0$0D$0ADL1System Not Ready$0D$0ADL2For help, press~$0D$0ABZ0$0D$0AP] Line 111 (15:28:05):: String From [5001:7:1]-[A1rasceeps$0D] Line 112 (15:28:05):: String To [5001:7:1]-[4$0D] Line 113 (15:28:06):: String From [5001:7:1]-[$0ALB0$0D]
Shane
What reaction were you expecting to the line feed character? Notifications printed it, so its done its job. What you are likely seeing is that the device isn't speaking in complete sentences, so you see parts of or combined commands that you then have to combine and parse in your code. If you get a line feed that's the start of the command and the carriage return is the end. That should be pretty easy to parse, but you might have to concatenate the serial strings as they come in before parsing.
DATA_EVENT[NX587Port] { STRING: { cBuffer="cBuffer,DATA.TEXT"; cTmpString=REMOVE_STRING(cBuffer,"$0D",1); WHILE(cTmpString!="") { fnDoSomething(cTmpString); cTmpString=REMOVE_STRING(cBuffer,"$0D",1); } } }Every other device I'm familiar with gives me a fresh line in the notifications so that I can use Left_String and Mid_String keywords with predictability. The run on sentence that I am getting here is what has me boggled. I couldn't think of the correct syntax to break this data into the parts that I need.
shane
Allot of devices send their data in fragmented chunks so you have to wait for a string to be complete before it is parsable or more easily parseble.
Using your example your would need to add an additional while loop:
DATA_EVENT[NX587Port] { STRING: { cBuffer="cBuffer,DATA.TEXT"; WHILE(find_string(cBuffer,"$0D",1)) { cTmpString=REMOVE_STRING(cBuffer,"$0D",1); WHILE(cTmpString!="") { fnDoSomething(cTmpString); cTmpString=REMOVE_STRING(cBuffer,"$0D",1); } } } }For me I would probably loose the 2nd while loop and just do:DATA_EVENT[NX587Port] { STRING: { cBuffer="cBuffer,DATA.TEXT"; WHILE(find_string(cBuffer,"$0D",1)) { fnDoSomething(REMOVE_STRING(cBuffer,"$0D",1)); } } }and put that while loop that was removed into fnDoSomething() since that's really where it belongs as part of that routine.Actually, my example and your code are equal. You just took away variable cTmpString which doesn't really need here. And why do you need second loop ?
They're not the same at all, close but not the same. Your method leaves parseable data in the buffer by only grabbing the 1st occurrance of $0D and then only deals with that while my method will grab and deal with every occurrence of $0D that may come in a single data event which is what happens in the OPs diagnostic print out. Read what I posted again and if you still don't get it I'll try to explain it better. Right now I'm not near my PC so it's hard to post examples.
