Home AMX Resource Management Suite Software
RmsAssetParameterEnqueueSetValue() doesn't work
I'm trying to track down some issues with initializing values for assets, and as best I can tell RmsAssetParameterEnqueueSetValue() just doesn't work.
These are the commands being sent by the code:
ASSET.PARAM.UPDATE-5001:3:1,filter.consumption,SET_VALUE,455,false
ASSET.PARAM.SUBMIT-5001:3:1
The SUBMIT doesn't seem to actually do anything. If I change things to send:
ASSET.PARAM.UPDATE-5001:3:1,filter.consumption,SET_VALUE,455,true
it works perfectly. What is going on? Do parameter updates just not work when queued?
  • Try this submit command instead for queued updates:
    ASSET.PARAM.UPDATE.SUBMIT-5001:3:1
    "ASSET.PARAM.SUBMIT" is the submission command for registering asset parameters and "ASSET.PARAM.UPDATE.SUBMIT" is the submission command for updates to existing asset parameters.
  • mstocummstocum Posts: 120
    I'll give that a try later today, and report back (I'm in the middle of testing some other things at the moment). I think there may be an error in the RMS boilerplate code that comes with the SDK, though. From RmsNlVideoProjectorMonitor.axs:
    DEFINE_FUNCTION SynchronizeAssetParameters()
      // This callback method is invoked when either the RMS server connection
      // has been offline or this monitored device has been offline from some
      // amount of time.   Since the monitored parameter state values could
      // be out of sync with the RMS server, we must perform asset parameter
      // value updates for all monitored parameters so they will be in sync.
      // Update only asset monitoring parameters that may have changed in value.
      //Synchronize all snapi HAS_xyz components
      IF(SynchronizeAssetParametersSnapiComponents(assetClientKey))
        RmsAssetParameterSubmit (assetClientKey)
    I think that the last line should be RmsAssetParameterUpdatesSubmit(assetClientKey) instead.
  • I think you are correct ... that looks wrong. I'll pass this along to the development team.
    In just a quick spot check, it looks like all the RmsNL** modules may suffer from this issue.
    The touch panel, DVX, and PDU monitoring modules look correct.
    Thanks!
    Actually, I was able to test that quicker than I thought and it looks like it solved it. Thanks.
    Thanks!
    If you're reporting things to the development team, could you also have them look at the issue I had in this thread http://www.amxforums.com/showthread.php?9567-Asset-Parameter-Initialization ? In RmsNlSnapiComponents.axi, it looks like either KeySetValue() or keyLookup() needs to set uKeys.cName, but neither of them do. From the comments above the functions, I think keyLookup() is supposed to do it, instead of KeySetValue() which is how I solved it.
  • Will do! I'll comment in that thread also.
