Who did work with nexia tc?
Tassadar
On 7s and 8s inputs i have a radio microfons. And i need command to mute them.
This SET 1 INPMUTE 129 1 1 or SET 1 AECINPMUTE 129 1 1 or SET 1 PAECINPMUTE 129 1 1 are unworkable. Nexia answers me Invalid SVC. What i can do?
Sorry for bad english, thank you for adwise
It looks like you have the right command, let me break down the syntax
SET [DEVICE #] INPMUTE [INSTANCE ID] [INDEX] [VALUE]<LF>
Since it is a Nexia TC I assume it is 1.
Make sure the instance ID is correct. This is not the same for all Nexia systems. If you programmed the Nexia make sure you check this. If someone else did that programming ask them to check the Instance ID on the AEC input block.
The index is the number of the input on the block. You will want to use 7 and 8.
Value is 1 for mute, 0 for unmute.
<LF> is Dec 10 or Hex $0A
Make sure you have the right Instance ID and use Index 7 and 8 and it should work.
{ If (NexRxMuteStat = 0) < if not muted flag
send_string dvBiamp,"'SET 1 TIRXLVL 134 -99',$0A" < mute it (look at the -99)
NexRxMuteStat = 1 <set flag
Else IF (NexRxMuteStat = 1) <<else if the flag is muted
send_string dvBiamp,"'SET 1 TIRXLVL 134 -38',$0A" <come back to a low nice value
NexRxMuteStat = 0 << reset flag
-ERR:# 0x0
-ERR:XACTION ERROR
-ERR:INVALID SVC
- INVALID OBJECT
What it means?
- Chip
