Home DigiTech Forum DigiTech GNX Archive Threads GNX4 FAQs GNX4 Sound Community Archive
question on patchesi
i have download a pack of patches from main website
i have got some problem that only some patches when uploaded then i can't use the stompbox,mod and delay switch to on/off respectively. I'm sure that i have change the mode to stompbox mode already...
thank you, this is really headachedic
  • shreddshredd Posts: 5,649
    If you have such problems, the settings of those particular patches are probably not set as you want them. Open them in XEdit and check the settings and put them the way you want. Sounds like you have some problems with footswitch assignments.
    And when you're feeling less \"headachedic\", fix me up with one of your groupies. 8)
  • guitar3456guitar3456 Posts: 3,494
    Control A B and C assignments probably need reset to default for stompbox mode. Some presets may have other variables selected from other source parameters.
    Go to the EXP assigns
    Set Cont A to STOMP ENABLE
    Set Cont B to MODUL ENABLE
    Set Cont C to DELAY ENABLE
    If you are in record mode, those same switches are now an active transport ie Stop/ Undo, Record and Play.
