Home DigiTech Products
Digitech JamMan Solo XT - footswitch input
Good day!!!
I own a Digitech JamMan Solo XT, along with the 3 pedal footswitch.
Everything was working fine, but we could have made a mistake, by connecting to the footswitch input of the JamMan Solo Xt a cable directly from an earphones output from a Multi-Effect Processor Pedal, the footswitch pedal stopped working since, /-¿Any advice on this issue, and do you think that this could be related to the mistake mentioned above___?? Any recommendations ?? something that I could do?
The pedal by itself seems working fine.
Thanks and looking for your advice.
Answers
  • Hello, I would make sure that you have the FS3X Footswitch connected to the Footswitch port with a TRS 1/4" cable. If you're using the Aux In I do not think that should affect the FS3X. Maybe try factory resetting the JamMan Solo XT?
