Home DigiTech Products
trio plus band creator + looper
the "part" LEDs are all flashing red. The micro card is installed. Did a factory reset. still flashing red
  • is it possible to but a "new" micro card for the Trio plus?
  • Any microSD Card can work with the Trio+ typically, here are the minimum requirements:
    The TRIO+ supports microSD cards that meet the following specifications:
    • microSDHC
    • 8 GB–32 GB
    • Class 10
    You can also try to reformat your MicroSD card with a card reader on your PC and then see if it works by inserting into the Trio+
    Also make sure that the MicroSD card inserts fully and is flush with the chassis, you push it in and it should retain the card, just as you would push it in again and let it release etc.
