Home Lexicon User Forum Lexicon General Discussion
Lexicon Alpha USB autosuspend issues
I have an issue with my Lexicon Alpha Studio (audio interface). During use the USB disconnects itself (Blue USB light OFF). I have Googled it, and apparently this is down to the "USB autosuspend feature"? It also says that I need to change the setting in the tlp configuration file?? Any help would be appreciated please...thanks - Col
  • HARMAN_EEldeHARMAN_EElde Posts: 1,366
    If your computer goes to sleep, then the Alpha will lose it's connection to the system, we've never found a viable workaround for this other than unplugging the USB cable and plugging it back in
  • Changing your buffer size will definately lower the latency. But.. When you're mixing put your buffer size back up to a large number it allows your CPU a little more wiggle room for processing with all your vst's running..
