Eon One breaks down during performance
Pierre1
Hi
I have been using an Eon One old type, in Panama which breaks down during performance . It’s sort of start off OK then about 20mins later, noise distortion And noise reduction Take place at a significant notable level.
However when the live performance is done I use the blue tooth to play music and it works fine. Does anyone have a suggestion as to what is wrong with it, and the best way to fix it. I’m in Panama so it really hard to find engineers to do the work, it will probably need to be done by myself.
2
Try putting a fan behind it to blow into the power amp section. If that solves the problem, you have an overheating issue.
