Home Lexicon Software
MAC OS 10.14/10.15 - PCM Native Reverb and Effects - version 1.3.9/1.2.9 - download now!!
HARMAN_EEldeHARMAN_EElde Posts: 1,075
edited April 16 in Lexicon Software
Public Beta Fix for Mac OS 10.14/10.15 versions available now to download
PCM Native Reverb Version 1.3.9 - https://help.harmanpro.com/pcm-native-reverb-installer-for-mac
PCM Native Effects Version 1.2.9 - https://help.harmanpro.com/pcm-native-effects-bundle-installer-for-mac
This does not include official Big Sur compatibility but that is coming (customers have reported it working with Big Sur as of now)
  • F.Y.I. The public Beta releases of PCM Native Effects and Reverb [both] installed successfully on my Big Sur Mac with latest patches. I use Universal Audio's Luna and the new native effects and reverb plugins load successfully and appear to work within Luna. I'll post any issues I run across.
  • HARMAN_EEldeHARMAN_EElde Posts: 1,075
    Thanks for the update @focusritegreen3
  • marcusenfpmarcusenfp Posts: 6
    Activation is failing for me when I start Logic Pro X with the new plugin updates. I have a screenshot showing both my iLok confirmation screen, and the new Lexicon Plugin denying it exists. When I re-input my registration number, it says it's maxed out. PLEASE HELP!
    I suspect that the new updater does NOT uninstall previous versions. I tried using the uninstaller for version 1.2.1, which you gave us in the interim, and it says "The Uninstaller needs to be updated by the publisher". PLEASE HELP!!!!
    If you are getting activation notifications, uninstall and reinstall iLok License Manager:
    https://www.ilok.com/#!license-manager
    If you're still having issues, contact Tech Support in my signature below.
    Is there a problem @FlorianS hmmm?
    Confirmed: Activation is grabbing versions 1.2.1 because the new updates do not uninstall this previous version, and the uninstaller for version 1.2.1 says "The Uninstaller needs to be updated by the publisher". Perhaps @FlorianS didn't have any previous versions installed? Any advice? Do I need to learn how to drill down into the file structure and find where 1.2.1 lives and manually delete it?
    edited March 18
    Okay you're talking about LXP Native Reverb Bundle 1.2.1 the previous version - please note that this thread is specifically about PCM Native Effects and Reverb for one, not LXP Native Reverb, there is a separate thread for that update. I will direct message you.
    Keep in mind, all the software have new uninstallers that work but this thread is specifically for the PCM Native Reverb/Effects Bundles, but if you downloaded PCM Native Reverb and Effects bundles from this thread and have LXP Native Reverb Bundle it will not work. You need to uninstall those. LXP Native Reverb Bundle 1.2.3 is at this thread:
    https://proforums.harman.com/lexicon/discussion/137567/mac-os-10-14-10-15-lxp-native-reverb-bundle-public-beta-1-2-3-now-available-download-here#latest
  • Geri_OGeri_O Chief Engineer, AVA Entertainment Studios, Jackson, MS Posts: 4
    YAY! Lex Native effects Bundle installs now! Using Studio One 5.2 on MacBook Pro Catalina 10.15.7
    This was the only thing keeping me from mirroring our studio PC. Glad to have it running.
    Now I'll update to Big Sur and totally screw things up!.... :D:D
    Thanx, guys.
    Thanx, guys.
    Glad to hear it @Geri_O
    @focusritegreen3 said he is running it fine on Big Sur, so take that as you will!
  • FlorianSFlorianS Posts: 1
    @HARMAN_EElde
    Sorry mail problem to activate my account
    I have cpu peak with 3 plugins :
    NativeChamber ,
    FAIL @ 64 ,128, 256 ,512, 1024 BUFF.
    60% cpu peak @ 2048
    NativeHall,
    FAIL @ 64 ,128, 256 ,512, 1024 2048 BUFF.
    NativeConcert Hall
    FAIL @ 64 ,128, 256 ,512~, BUFF.
    34% cpu peak @ 2048
    Protools 2020,12
    MacPro Mid 2010 8 core
    OSX 10,14,6
    NVIDIA GeForce GTX 680 2 GB
    Mail already send to support with video.
    @FlorianS said:
    @HARMAN_EElde
    NativeChamber ,
    60% cpu peak @ 2048
    NativeHall,
    NativeConcert Hall
    34% cpu peak @ 2048
    Protools 2020,12
    OSX 10,14,6
    Yes I talked to my colleague in support already and they informed me you had contacted them. Doesn't really explain why you would disagree with my post nonetheless, because these were fixes for compatibility for plugins to run on Mac 10.14 and 10.15, your issue is separate from that.
  • doctaj54doctaj54 www.nukmusiccompany.com Posts: 1
    edited March 27
    I'm looking forward to the official release.
    my post from Lexicon thread on Gearslutz
    **_Just did some testing with the 1.3.9 beta.
    12core 2010 Mac Pro running ProTools 2020.12 Ultimate on Mojave 10.14.6
    Overall, the 1.3.8 dmg is 562mb and the 1.3.9 dmg is only 284mb. The individual AAX file for each reverb are also about half the size of the previous version. The Hall, Concert Hall, and Chamber reverbs will load but immediately trigger a cpu spike and 9173 error when I try to playback the session no matter what the buffer setting would be. When I click and open the plugin info, those three show "1.3.8, Feb 26, 2021". The other reverb types load and seem to run without issue even when I option-click-drag to add another just below it. Their info shows as "1.3.9, Feb 27, 2021".
    You definitely need to re-insert the newer version of the reverbs were you had a previous version in a session. The original fader settings do seem to be reload into the newer versions but the category and the preset settings are totally different from the original setting. Maybe Lexicon can fix that. The newer versions do load faster but still are a little slow to un-insert or to disable. I didn't do any listening tests so I'm not sure if they sound the same. I will try 1.3.9 on my Macbook Pro running Catalina when I get time._**
    The process is ongoing yes. Nothing has changed in the Reverb algorithm.
  • DrinDrin Posts: 5
    Native Effects now works fine on my Catalina system. Thanks! :)
  • santamorphicsantamorphic Posts: 1
    edited April 18
    How do I get hold of these updates, please? The downloads in the public site don't work on Catalina and the links in the first post of this thread require a dealer logon. Currently unable to use the plugins. Thanks!
    There was an issue with the public facing links, they should be resolved now. Try it again.
  • JohnnieharrisJohnnieharris Posts: 2
    Cool deal, Thanks!
    I saw the new download links and will try it out. I'm really hoping for iLok cloud authorizations as well.
    @Johnnieharris said:
    Cool deal, Thanks!
    We will not be using the iLok Cloud, but the idea is to do away with iLok/Pace authentication altogether. No idea when this will happen but we will announce it when we have an ETA for that phase of the plugin development.
  • @HARMAN_EElde
    Ok Thanks!
    It will be nice to not have to move my iLok authorization from the one ilok to the other. I run Protools and Logic on my Mac Pro and Macbook Pro at different times.
