Checking NI Master without User interface.
Hello,
Is there any way to check your programming without user interface.
Does the processor response to the commands.
I think its debugging but what is the best way to understand for ex. i want to check my program for relay channels. What is the procedure?
Thank you,
    You can use Control Device and Emulate Device in NS in the Diagnostics menu to simulate real stuff doing stuff.
  • champchamp Posts: 261
    You could try the Virtual Keypad http://www.amx.com/products/NDT-VKP.asp if you must have a UI at no cost, it's basic but better than nothing.
    I use an iPad and TPControl 180 day license, as long as your employer sells a license every 180 days you can get the token reset to 180 days.
