VST Thermostat installation
in AMX Hardware
Hi,
I have a VST thermostat, connecting up to the netlinx looks straightforward. Having no experience of heating systems I asked my plumber to take a look and he is unsure how to connect.
I have a very simple system, just a boiler (no aircon).
Does anybody know which wiring diagram I should use?
Thx,
Phil
Thx,
Phil
There is a detailed diagram in the Viewstat Installation manual.
All of the diagrams in the manual seem to involve a much more complex setup...
Kevin D.
Here is something I have discovered about Viewstats that I really don't like at all: there is no definite isolation between the communications lines and the HVAC lines. I have seen the entire comm buss wig out because an HVAC tech disconnected the furnace, and that on a system where the stats had their own power transformer, so it wasn't a power issue. I believe the lack of isolation is on the ground - it's common throughout the stat, so the common line on the HVAC lines is also the signal ground on the comm buss. I strongly advise buying the external relay cards from April Aire to isolate the furnace and compressor from the thermostat.
I have a whole system going in shortly.
There are several outboard relays available, most of which are intended for specific multi-stage furnace types the thermostat does not support directly. The old Enerzone number for them was DF2 and DF3; that's how I have them in my database, and I have no idea what the new Aprilaire number is. You could probably do the same job with another make relay - just need a 24V trigger.
