Send_Command Response From a MAX-CSE
Hi All,
i'm currently trying to get response from a MAX-CSE.
SEND_COMMAND ENCODER, 'GET STREAM STATUS'
The unit is set has
ENCODER 32001:1:0
i have create a buffer
CREATE_BUFFER ENCODER, ENCODER_TBUF
The ENCODER_TBUF is set to 100
char ENCODER_TBUF[100]
i'm currently using the com port of the MAX-CSE ENCODERS232 32001:2:0 and the command and response works perfectly for the comport.
but someone can help me to figure out why i can't receive any response from the unit when i'm trying to get information from the Port 1 of the MAX-CSE.
The unit is set has
ENCODER 32001:1:0
It should be set in a range 5001-5999
Then port 2 is used for serial commands/strings.
So if it's set to 32001 then 32001:2:0 is the serial port
The Serial Port works fine, i'm able to send/receive command from the serial port of the MAX-CSE.
The problem is i sent a command to the Port 1 (Streaming Command) of MAX-CSE. The command is working when i set parameter
SEND_COMMAND ENCODER,"'PLAY'"
SEND_COMMAND ENCODER,"'SET ASOURCE MIC'"
but the port didn't return feedback when i sent a get command. those get command are supposed to return a response of the actual status.
SEND_COMMAND ENCODER,"'GET VSOURCE'" should return VSOURCE = COMP
Does it mean i need to set the the MAX-CSE to and address between 5000-5999 to be able to get response from port 1
http://www.amx.com//assets/manuals/MAX-CSE.CSD.OperationReferenceGuide.pdf
port 1 is for stream commands
port 2 is for 232 commands
can you post some code? It might help figure out what you're trying to do
command responses should come back on port 1 - how are you capturing them?
you should have:
data_event[ENCODER] { command: { send_string 0, "'Command Received: ', data.text" //process response here } }then for your 232 responses:
data_event[ENCODERS232] { string: { send_string 0, "'String Received: ', data.text" //process response here } }Thanks ijed,
i was using String: instead of Command:
now it's working.
by using data.text i don't need to use create_buffer anymore?
Also, just so you know... Data.text has a 2K size limit. With Create_Buffer you can go well beyond that size. So, for things like web page interfacing, large XML files and so forth you will need to go with C_B to avoid truncated messages.
