NI 3100 FIRMWARE UPDATE
AFTER DOWNLOAD THE NEW FIRMWARE ( V 1.30.8) AND TRY TO UPDATE FIRMWARE ON NI3100 (V 1.13.6). WE WERE NOT BE ABLE TO UPDATE, THERE WAS ERROR " TRANSFER ABORTED - FIRMWARE IS INVALID -
WE HAVE REBOOT THE MASTER, REDOWNLOAD FILE BUT NOTHING SEEMS TO WORK.
ANY IDEAS? PLEASE HELP
  • Hi,
    Look at the Target device id: 5001 for the SW2105_NI_X100_Device_v1_30_8.kit file.
    And if you update the master use Target device id: 0 and file SW2105-04_Master_v4_1_373.kit.
    After a reboot you can see the correct version.
    Be sure you grab the correct file and switch Caps Lock OFF to keep it friendly ;)
  • Worked
    Thank you so much. It updated. I make sure the CAP Lock is off :-)
